need help on my 1991 honda crx si with b16...PLEASE!!!
ima try my best to explain this.here i go...i own a 1991 honda crx si with an obd-0 b16...i was drivin 3 days ago on the freeway goin about 80 when the rpm suddenly dropped when it got to 5 rpms..then 2 seconds later comes back up to 5 rpms.so i didnt think anything bad.then yesterday.i went to my car to warm it up.i started the car and 5 seconds later.the car turned off on its own.so i was like wtf.i tried to start the motor and wouldnt turn on.i gave it about a minute.then it started.i took it out for a drive on the street.i got to maybe 50 mph.and the rpms dropped and the car turned off.its been doin this and i cant figure out whats wrong with it.it doesnt throw any code. so if u guys can really help me out.i would really appreciated.i hope i explained it well.........thank u guys
your best bet will be that some wires got rain on and are causing a false ground or something i had the same proble my rpm will drop when i hit bump or something and it was a wet wire that wasnt grounded right from the harness.
check your main relay. happened to me a month ago, car was idleing fine on its own then suddenly died. it never started again.
checked everything and all seems to be perfect except i replaced the main relay with a brand new one and car works perfect till now.
check your ignitor...if you can afford it just replace it...if its old or a parts store one it WILL eventually go out anyways....on a side note...GET A GENUINE HONDA ONE!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16crexster »</TD></TR><TR><TD CLASS="quote">the next time it is running try to tap the dizzy with a screw driver and see if it shuts off? it could be that that happened to one of my boys
</TD></TR></TABLE> you sound like a ******* idiot. cause you know hitting things makes them work fine if not better. theres other ways of testing things other than hitting them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efrex »</TD></TR><TR><TD CLASS="quote">i was told by 3 guys today its the main relay...and 1 guy said igniter..how much is an igniter?...thanks guys
dont quote me on this...but if I remember right around $75...
does the fuel pump prime when you turn the key to the "on" position (can you hear the fuel pump?
</TD></TR></TABLE>dont quote me on this...but if I remember right around $75...
check all your wiring that you might of changed. I recently switched back to dpfi
for smog, now that the weather is getting hot my electrical tape is coming off my wires and i had one wire come apart and my car ran like ****. That main relay and igniter stuff sounds good too. Good luck.
good luck with that. i have a simaler problem right now. cant wait to hear how yours goes. unless its bad ofcoarse but i got a new ignitor from my local honda swap shop and they sold it for 40 bucks but they had the parts lying around good luck with that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efrex »</TD></TR><TR><TD CLASS="quote">yeah.i hear the fuel pump</TD></TR></TABLE>
In my expeirence...if the fuel pump does kick on...its typically not the main relay...
like another said its getting warmer outside...and ignitors tend to fail when it gets hotter...
