my projects
Old Jun 15, 2006 | 07:57 PM
JJ's civic's Avatar
Default my projects
fist time posting pic hope it comes out right
this is my dd
this will be my project prob next spring (need to fix the dd first. front end is shot and motor smoking.)
these rims are for my dd but the front is so bad i can't drive with them.
hope the pics come out arite.
and for the new car she was trying to get the honda si ut couldn't aford it
Modified by joeny12985 at 12:19 AM 6/17/2006
Modified by joeny12985 at 8:38 PM 6/20/2006
Modified by joeny12985 at 8:39 PM 6/20/2006
Old Jun 15, 2006 | 08:01 PM
philkehn's Avatar
well you forgot to put the link to your pic?
Old Jun 15, 2006 | 08:16 PM
JJ's civic's Avatar
Default Re: (philkehn)
how do i put the link in? it's off my pc what do i type like the dir where it is on my pc?
Old Jun 15, 2006 | 08:24 PM
philkehn's Avatar
you gotta post it on the net then put the link to it go to http://www.photobucket.com
Old Jun 16, 2006 | 08:20 PM
JJ's civic's Avatar
Default Re: my projects (joeny12985)
bump put the pics up.
Old Jun 16, 2006 | 10:01 PM
:chilly's Avatar
so what are the plans?
Old Jun 16, 2006 | 10:31 PM
JJ's civic's Avatar
Default Re: my projects (:chilly:)
well with the dd the motor from the other one is gong in SOON then a mdfi swap and a front end bushing and ****.
the other one rebuild d15 with d16 parts for now then a h22 for drag only the project one is going to be all out it's goign to be built and then rebuilt differnt motor trannys suspesnion it's my first project and it will be beaten on HARD.
the neon hopefully sum kind of turbo damn thing can't past a snail if i had too
Old Jun 16, 2006 | 10:57 PM
SD_Lurker's Avatar
HT White Ops
great start!
Old Jun 17, 2006 | 12:17 PM
JJ's civic's Avatar
Default Re: my projects (nicks_jdmstyle_ef9)
thankx the primered one i got for $900 with the rims and tires that are on the front of the other one. it had 302000 on the odo and since then(step) i've put 20000
Old Jun 17, 2006 | 02:59 PM
LankorDie's Avatar
Loved
Community Favorite
Bump for random image sizes
Old Jun 17, 2006 | 03:36 PM
JJ's civic's Avatar
Default Re: my projects (LankorDie)
yea i dont know how i did that or how i can fix it i'm stillkinda of new to h-t
Old Jun 17, 2006 | 04:05 PM
FernEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LankorDie &raquo;</TD></TR><TR><TD CLASS="quote">Bump for random image sizes </TD></TR></TABLE>
lol yea true that... nice project u got tho, good luck
Old Jun 17, 2006 | 04:17 PM
JJ's civic's Avatar
Default Re: my projects (FernEF)
how much does a mpfi swap cost about? i'm thinking of dong that to my dd
Old Jun 17, 2006 | 08:30 PM
philkehn's Avatar
do it your self
http://hybrid.honda-perf.org/t...g.htm &lt;----- check this link, its not to hard
Old Jun 17, 2006 | 08:38 PM
JJ's civic's Avatar
i do plan on doing it my self i was asking how much it would cost for parts.
Old Jun 17, 2006 | 09:00 PM
harmonator84's Avatar
Default Re: (joeny12985)
just grap you a harness out of another car that is mpfi
i will be selling one in acouple weeks..getting ready to strip down my HF
Old Jun 17, 2006 | 09:13 PM
philkehn's Avatar
you would need the harness and the resistor box you can get the resistor box at the junk yard for a couple bucks... you actually dont need to get the mpfi full harness all you need to do is
Get 4 injectors for the correct series of your engine
Wire each injector to the right pins at the ecu...
im pretty sure it goes as
Injector 1 to pin a1
Injector 2 to pin a3
Injector 3 to pin a5
Injector 4 to pin a7
Then wire each of the red wires that come from the injector, this is the second wire that comes from the injector the are all red, so just wire each of the red wires to the red wires coming from the resistor box.. then from your dx harness take the two old injectors at the cut them as close the the plug as you can.. then wire the to yellow/black wires from each injector together, then from there follow another wire to the yellow/black wire from the resistor box..
The next part is where it gets a little tricky
At the ecu you have to cut wires
Cut wire C1 and from the pin run the wire all the way the dizzy and wire to the blue/green wire on the dizzy
Cut wire C2 and do the same thing from the pin attach to the blue/yellow at the dizzy
Run the old wire from C1 coming from the chassis half to B10 (Orange wire) and the old wire from C2 to B12 (White wire)
Please solder
Old Jun 17, 2006 | 09:23 PM
JJ's civic's Avatar
i pretty much know wha ti need to do i'm jsut wondering how much willit cost for parts.?
Old Jun 17, 2006 | 09:37 PM
junk yard 20-75
ebay 50-125
Old Jun 17, 2006 | 09:42 PM
JJ's civic's Avatar
Default Re: (harmonator84)
20-70 bucks for everything?
Old Jun 17, 2006 | 09:52 PM
well for your harness
and a resistor box is usually like 1-5 bucks
for a junkyard around here...yes
Old Jun 17, 2006 | 09:58 PM
JJ's civic's Avatar
i was thinking it was going to cost me like $300 bucks.
Old Jun 18, 2006 | 07:36 AM
philkehn's Avatar
yea the junk yards most likely wont know what the resistor is when you take it up there so there wont be to much of a charge, and you dont need a hf or si harness unless you want to save the work of wiring the injectors... if you do get an si or hf harness all you have to do is switch around the wires at the ecu and run the 2 wires to you dizzy
Old Jun 18, 2006 | 02:25 PM
JJ's civic's Avatar
you dont need a differnt ecu? or si that only if you change from odbo to odb1?
Old Jun 19, 2006 | 03:47 PM
JJ's civic's Avatar
bhow hard is it to convert to odb1
