mini me swap won't start HELP
Old Jun 15, 2006 | 07:36 PM
sillyme77's Avatar
Default mini me swap won't start HELP
just did a mini me with a Y8 head from a 2000 civic ex. i'm using the stock si computer til i get my obd0-obd1 jumper. i used the y8 map on top of the throttle body instead of the si one. is there something special i forgot?
Old Jun 15, 2006 | 07:51 PM
AZTEKEF9's Avatar
Default Re: mini me swap won't start HELP (sillyme77)
wich distributor r u using?
Old Jun 19, 2006 | 12:42 PM
sillyme77's Avatar
using the a6 distributor
Old Jun 19, 2006 | 12:49 PM
DIYMIKE's Avatar
Default Re: (sillyme77)
any codes?
i just did the same swap. check your timing. spark and fuel. and if all else fails compression.
Old Jun 19, 2006 | 02:42 PM
sillyme77's Avatar
i check for spark: yup, fuel: plenty, timing is right on. don't have the idle air control plugged in yet. don't think it will cause it to not start. i put a new tps sensor on. how do you adjust that damn thing? i'm guessing that's why it won't start.
Old Jun 19, 2006 | 02:48 PM
xxmikexx206's Avatar
make sure the timing is advanced 2 degrees... it wont run without like that, or if it does it will run like crap
Old Jun 19, 2006 | 02:54 PM
sillyme77's Avatar
got a number i can reach you at? sure could use the help. thanks
Old Jun 19, 2006 | 03:46 PM
sillyme77's Avatar
set tps sensor at 0.44 voltage closed. timing advance a few degrees. anything i'm missing?
Old Jun 20, 2006 | 04:24 PM
you should still be able to plug everything in.... all the connectors are the same, so try plugging the iacv in and see(why not? its worth a shot right!!!) i did the same swap to my crx only with a z6 head and zc bottom end, timing was most of the problem on starting, its got to be really precise. to do so put on the belt as usual, do the 2:1 revolution just make sure all is good, then advance the cam gear 2degrees, then set the ignition timing 16 degrees +/- 2degrees... its all simple its just very time consuming to get it exact, and believe it has to be exact
Civic361
Dec 3, 2012 09:25 AM
julianbc2
Jun 8, 2011 02:52 PM
turbotegy10
May 13, 2011 06:53 AM
Stevens2266
Jul 16, 2008 08:09 PM
shauniewalnuts
Jun 27, 2005 08:20 PM
