94 Integra ls Turbo plans... Need some help please
Old Jun 15, 2006 | 07:20 PM
94Integra_Ls's Avatar
Default 94 Integra ls Turbo plans... Need some help please
Hey all, I drive a 94 integra b18b obd1 with almost 230,000 miles on it.. motor still runs strong and has never leaked oil in its life.. well I have finished all cosmetic features on the car, and now I'm wanting to go faster.. I'm trying to get some ideas for a turbo setup, and what parts like pistons and rods ect... that i will need to prepare.. this car is my daily driver so i dont want anything huge power, maybe somthing to put me in the high to mid 12's in the 1/4.. ne help will be greatly appreciated..
I need help on the parts to get Turbo pistons rods ect. and im not wanting to spend a ton ton ton of money.
Old Jun 15, 2006 | 07:42 PM
Default Re: 94 Integra ls Turbo plans... Need some help please (94Integra_Ls)
any one?
Old Jun 15, 2006 | 08:31 PM
sorry to bump,,, but i need help
Old Jun 16, 2006 | 12:23 PM
my posts arent working,, so sorry if this comes up double...can anyone help??
Old Jun 16, 2006 | 12:53 PM
jdmbb6-t's Avatar
I wouldn't boost any motor with 230,000 miles on it... you should do a rebuild on that motor first.... and that alone will leave you broke depending on the quality of parts you use.
Old Jun 16, 2006 | 01:30 PM
Default Re: (jdmbb6-t)
well i talked to a buddie and he said as long as i bored out the block 1mm over i should be fine. he also told me that i will need forged pistons new rods stage 2 clutch light weight flywheel and cams, and a 2 1/2" exhaust turbo back.. does that sound about right
Old Jun 16, 2006 | 01:39 PM
Chris99SI's Avatar
Default Re: (94Integra_Ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Integra_Ls &raquo;</TD></TR><TR><TD CLASS="quote">well i talked to a buddie and he said as long as i bored out the block 1mm over i should be fine. he also told me that i will need forged pistons new rods stage 2 clutch light weight flywheel and cams, and a 2 1/2" exhaust turbo back.. does that sound about right</TD></TR></TABLE>
Bore it .5mm over, not 1mm. Otherwise you should be fine. You dont need a lightened flywheel or aftermarket cams also.
Old Jun 16, 2006 | 01:46 PM
jdmbb6-t's Avatar
while your rebuilding dont forget to change oil pump, water pump and get all new gaskets for the car.... I would go 3" on everything, for the exception of the IC piping. Just make sure you dont go the cheap route like getting used parts (ALL OEM HONDA!!!!)
Old Jun 16, 2006 | 02:34 PM
i didnt mean ti put cams... here is my setup so far
Exclusive custom imports Turbo Charger $2,000 shipped
Gripforce Clutch and Flywheel 263.00 shipped
Arizona race engineering LSD 229.00 plus 200.00 shipping
valve job 150.00
forged 9:1 pistons 380.00
block work 300.00 + 100.00 for new bearings
does this sound about right?
Old Jun 16, 2006 | 03:11 PM
Dc4turbo408's Avatar
why dont u just peice your turbo kit?
I say get a gt30r ball bearing turbo.. Im gettin bored of my 57 trin garrett.. I want faster spool..
Old Jun 16, 2006 | 09:21 PM
Default Re: (Dc4turbo408)
peice my turbo kit?
Old Jun 16, 2006 | 10:16 PM
if you guys/gals can come across better numbers for parts let me know.. trying to safe as much money as possible
Old Jun 17, 2006 | 02:22 AM
Sorry, it's piece.. My bad..
Old Jun 17, 2006 | 08:26 AM
no no ,, i knew what you meant... but what does it mean to piece my turbo kit
Old Jun 17, 2006 | 03:02 PM
Find pre used stuff that's in great condition.. N buy one or two at a time, so u can save your money.. Instead of just blowing it all up on a brand new kit... Which will function the same with the Used kit.. U know?
Old Jun 17, 2006 | 07:47 PM
stewie8apie's Avatar
it will take some good power to get high to mid 12's in the 1/4. what is this "Exclusive custom imports Turbo Charger $2,000 shipped" ??? i'd also say 3 inch turbo back instead of 2 1/2.
Old Jun 18, 2006 | 12:22 AM
Default Re: (stewie8apie)
thx,, all help/ideas are greatly appriciated.. the turbo is one the same brand that my buddie runes on his accord.. any suggestions on what turbo/turbo kit to get??
Old Jun 18, 2006 | 11:40 AM
so $2,000 for just the turbo? i'm confused as to why you'd use a $2,000 turbo unless you were going ***** out. you could just as easily reach your goals with a less expensive turbo. please elaborate if i'm wrong on this.
Old Jun 18, 2006 | 12:19 PM
the whole kit is 2,000 turbo intercooler piping bov ect...
Old Jun 18, 2006 | 03:23 PM
blackeg's Avatar
buy the turbo stuff and boost the current motor. i ran a boosted ls with 230k miles. if the motor gives in down the road, u have the turbo stuff and then you are just pistons and rods away.
if building the motor, necessary parts:
pistons
rods
headstuds
additional parts to help:
aftermarket im
crower 402-T cams
Old Jun 19, 2006 | 04:59 PM
Default Re: (blackeg)
well what do you all think would be a good setup for around 300whp or around a 12 second 1/4 times? any help is greatly appreciated.. and brand names of parts is also appreciated... remember im kinda on a tight budget.. i dont want to spend over $4,000
Old Jun 19, 2006 | 06:30 PM
any one?
Old Jun 19, 2006 | 07:03 PM
bkmc24's Avatar
Whats your email, i had a guy a little while ago give me a list for things to set up a kit when i had a Cl. He gave me brands and all the things ide need, i can senf them to you to help you out.
Ben
Old Jun 19, 2006 | 07:17 PM
Default Re: (bkmc24)
rydin24inchdubz5678@yahoo.com
Old Jun 19, 2006 | 10:10 PM
can anyone tell me a good turbokit to get? im new to forced induction and i dont want to purchase the wrong thing.. i do all this searchin on the net for turbo kits and i brings up an arsenal of them lol,, but i have no idea which ones are any good...
