Lower Tie bar problems on my crx help!!!
Old Jun 15, 2006 | 06:46 PM
ALLOUT CL55's Avatar
Default Lower Tie bar problems on my crx help!!!
hey i tried putting on a Benen Lower tie bar that came off a DC/EG on my 91 crx....but its off by half an inch...before i had a dc bar that came off a dc and it fitted cool...whats the deal??? help please....i was thinkin abotu drilling the hole a lil bigger but that defeats the whole purpose ...
heres a pic of one side bolted up....
Old Jun 15, 2006 | 07:26 PM
germz's Avatar
Default Re: Lower Tie bar problems on my crx help!!! (ALLOUT EM1)
just sell the benen and buy my crappy dc =] or just save the benen for another car.
Old Jun 16, 2006 | 03:20 AM
hahha...man i wanan keep this benen bar!!!!! hahahhahelp anybody???
Old Jun 16, 2006 | 03:36 AM
Autoworks's Avatar
The DC bar was adjustable. The solid Benen is more chassis specific. If you drill one side, you'll have to drill them both. If your set on having it, I'd mark and measure it and take it to a machine shop.
Old Jun 16, 2006 | 05:14 AM
CRX Toad's Avatar
I know I did this with an old Mustang but sometimes the body has flexed that it is warped. You could attempt jacking up the car in different location to see if you can get the body to flex enough to put it on there.
Old Jun 18, 2006 | 03:26 AM
ill try that....thanks!
Old Jun 18, 2006 | 10:14 PM
Jonknee's Avatar
Default Re: Lower Tie bar problems on my crx help!!! (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">I know I did this with an old Mustang but sometimes the body has flexed that it is warped. You could attempt jacking up the car in different location to see if you can get the body to flex enough to put it on there. </TD></TR></TABLE>Very clever
Old Jun 18, 2006 | 10:16 PM
fourthgenhatchB17's Avatar
Its gonna need to flex a TON!
I say just widen the holes equally on both sides and slap it on.
Old Jun 18, 2006 | 10:36 PM
RCautoworks's Avatar
Thats not good at all though, if you ever weld in a roll cage, the car should be on the ground with its weight.
I mean think about it, if you have to jack up one side in order to make the lower tie bar fit, whats going to happen when you let the car go back down. Either the tie bar is going to brake or the rear subframe.
Old Jun 20, 2006 | 12:30 PM
Default Re: Lower Tie bar problems on my crx help!!! (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
I say just widen the holes equally on both sides and slap it on.</TD></TR></TABLE>
i think imma just widen the holes on both sides...thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
I mean think about it, if you have to jack up one side in order to make the lower tie bar fit, whats going to happen when you let the car go back down. Either the tie bar is going to brake or the rear subframe. </TD></TR></TABLE>
thanks for info......
Old Jun 20, 2006 | 12:45 PM
ludesrv's Avatar
Shoulda bought one that was made for an EF . But ya, he's right. You need to trim the holes enough to get her one there. If I were you I'd take proper measurement and get a machine shop to do it. It would cost you maybe 50$ and it wouldn't look shitty/be off by anything.
Old Jun 20, 2006 | 01:01 PM
STREETWERKZ's Avatar
Default Re: Lower Tie bar problems on my crx help!!! (90blackcrx)
actually, a lot of race teams jack up one wheel or one side of the car when welding in a cage.
but to the OP: it wont work. sell off the bar to someone that has an eg/dc and buy the correct bar for your crx. it is way too long, i tried the same thing years ago. there is no way you can get it to PROPERLY work.
Old Jun 20, 2006 | 01:03 PM
Default Re: Lower Tie bar problems on my crx help!!! (STREETWERKZ)
actually, a lot of race teams jack up one wheel or one side of the car when welding in a cage. </TD></TR></TABLE>
Why, and what teams ? Maybe if you are going to be corning a lot or something.
I would want the cage to be welded in as how the car would be sitting on the pavement.
Old Jun 20, 2006 | 02:29 PM
but to the OP: it wont work. sell off the bar to someone that has an eg/dc and buy the correct bar for your crx. it is way too long, i tried the same thing years ago. there is no way you can get it to PROPERLY work. </TD></TR></TABLE>
yeha but the weird thing is my buddy has a crx and had the same benen bar and it came off a dc/eg...thats the only reason why i bought it because i thought it was gonna fit...maybe my frame is bent
Old Jun 20, 2006 | 02:32 PM
exactly...
Old Jun 20, 2006 | 02:45 PM
vanos_pusha's Avatar
i have the same bar (different color) and mine went on fine......
Old Jun 20, 2006 | 03:56 PM
Default Re: Lower Tie bar problems on my crx help!!! (two_cam_ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by two_cam_ham &raquo;</TD></TR><TR><TD CLASS="quote">i have the same bar (different color) and mine went on fine...... </TD></TR></TABLE>
when u bought your did it say it was made for dc/eg/crx??? should be all the same right???
Old Jun 20, 2006 | 05:11 PM
it should...mine was for a eg
93h22a1vtec
Jan 23, 2006 06:23 PM
blaznaznusmarine
Nov 10, 2005 07:21 AM
DeDonDeRosa
Feb 14, 2003 11:21 PM
