FS: Lots of CRX/aftermarket/oem parts! Mite!!
Old Jun 15, 2006 | 04:27 PM
SSJSubgeta's Avatar
Default FS: Lots of CRX/aftermarket/oem parts! Mite!!
Hey guys, whats up? Im parting out my project CRX
I put this ad as well in the regionals but I just want to get rid of this stuff.
A little info:
I turned the car on four time's after swap was done,that was so the engine wouldn't just sit there and not do anything. The car was never driven since i completed the swap so the items you see were just sitting and collecting dust. I rather pass these on to someone who would put them to use, so here we go.
These were on a 1991 CRX HF, and are D-series parts (D15B Vtec JDM), But keep in mind some items are compatible with other applications, but do your re-search.
Now with that said this is my first time selling stuff on honda-tech. I unfortunatly do not have paypal,I know it sucks. But I will only be shipping some items i can ship with ease and quickness.
I ACCEPT MONEY ORDERS at the moment.
Price are listed shipped!
Motor D15B Vtec SI Tranny and Axles were sold!!!
D-series Distributor (HF) $45 shipped
Unknown Distributor $45 shipped
HF Engine Harness converted from OBD-0 to OBD-1,Conversion Harness Obd0-obd1,dizzy conv.Piggy back harness for Vtec plugs, Knock sensor, OBD1 Injector plugs,New Denso 4 Wire 02 sensor,Resesitor Box removed.
SOLD!!!SOLD!!!SOLD!!!SOLD!!!SOLD!!!SOLD!!!
P28 ECU (virgin 5sp) $150 Shipped
PM8 ECU (Virgin) $50 Shipped
CRX Power package all 3 for $800 shipped
AEM Short ram intake $130 shipped
Megan racing stainless steel header 4-2-1 Header $130 Shipped
Espelir JGT500 exhaust system (Really nice Exhaust) $600 shipped
NGK spark plug wires $45 shipped
NRG hood lock pins with keys $35 Shipped
D Series Starter $35 shipped
Catalytic converter & gaskets $140 shipped
HF proportion valve $35 shipped
4040 porpotion valve $35 shipped
B&M short shifter With ES Shifter Bushings and Shift Linkage $110 shipped
(all hardware to install including Bitch pin!!! Type R style **** was sold!!!
B&M Fuel Pressure Regulator & Fuel Gauge Combo $100 shipped
An MSD Complete Ignition kit $270 shipped!
(MSD 6A box, MSD Blaster Coil and Modified MSD distributor cap.your choice of cap!)
Clutch Disc, Preasure Plate, Flywheel kit $270 Shipped
Excedy Pressure Plate $45 shipped
Resesitor Box $30 shipped
Front Toe Hook $20 shipped
HF Fuel Rail (same as a CRX SI) $25 shipped
OBD-0 Fuel Injectors $20 shipped
FRONT UPPER CONTROL ARMS, BOTH FRONT LOWER BALL JOINTS
LEFT AND RIGHT STABILIZER LINK KITS- Wth washers, bushings, sleeves, bolts and nuts, BOTH INNER TIE ROD ENDS $110 shipped
(OUTTER TIE ROD ENDS WERE SOLD)
D Series Mounts (EF) $40 shipped
1992-2000 CIVIC (Except 99-00SI)
ES Motor Mount Inserts $35 shipped
Mirrors $50 (both)+$20 shipped
CRX tail lights (all 3) $110 shipped
Climate Control - No craks! SOLD!!!SOLD!!!SOLD!!!SOLD!!!SOLD!!!SOLD!!!
Clutch Cable $30 shipped
Speed sensor cable $ 30 shipped
Throttle Cable $ 30 shipped
Rear Disc Conversion $260 shipped
New rotors, pads, ES rear trailing arm bushings.
CRX SI spindels/knuckles/hub assembly $90 shipped
Amber corners $25 shipped
Cig. lighter, JDM ash tray, $25 shipped
Headlights both $65 shipped
Gauge cluster $45 shipped
Cluster Cover $20 shipped
Center console $35 shipped
Radiator-new! $80 shipped
Comes with hose's,cap,excess tank
Rear Hatch struts $40 shipped
Windshield washe fluid Tank $35 shipped
motor is good, all hoses.
Thanks for looking and kindly Bump! if viewed.
E-mail: Subgeta@hotmail.com
AIM: SSJSubgeta
Modified by SSJSubgeta at 8:12 PM 6/17/2006
Modified by SSJSubgeta at 10:45 PM 6/20/2006
Old Jun 15, 2006 | 06:49 PM
88 rex's Avatar
Default Re: FS: Lots of CRX/aftermarket/oem parts! Mite!! (SSJSubgeta)
wow.........LOTS of stuff......bump
Old Jun 15, 2006 | 09:36 PM
661rex89si's Avatar
i just need the center tailight piece that says crx how much. shipped to lancaster california 93535 and the clutch kit and flywheel how about 250 shipped would this fit on a 89 si tranny
Old Jun 17, 2006 | 05:09 PM
SSJSubgeta's Avatar
Bump, P'ms replyed to and updated
HATCHIN238
May 27, 2012 10:48 AM
HATCHIN238
Texas -OK -LA (Sales)
May 23, 2012 09:48 AM
Tetanus
Mar 14, 2009 09:51 PM
Its me DUB
Nov 20, 2006 09:30 AM
