can't get transmission apart..
Old Jun 15, 2006 | 03:05 PM
shutta's Avatar
Default can't get transmission apart..
So after pulling my transmisison off (which was a real pain) I can't get the bell housing off of it. all the bolts are off and it seems like something is binding together inside the tranny. I was laking ooil and I didn't know it, and one thing leading to another, I was stuck in 4th with the shifter in neutral position, and coudl only go to 5th.. I couldn't go into any other gear.. fun. so anyways, I can pull the bell housing off about 2 inches before it sticks.. any ideas? I see decent chunks of metal around the tranny so I'm thinking when whatever happened inside, pieces of gears probably got jammed... so.. any ideas what coudl be holding this thing together? when I get it apart, i'm having it looked at to see if I shoudl get a "new used" m2B4 transmission for $600 or if I can get this one repaired. this one is an m2b4 as well..
Old Jun 15, 2006 | 03:07 PM
bb4socal's Avatar
Default Re: can't get transmission apart.. (shutta)
Honestly....seperating the tranny form the block is a BITCH! i had to use a pry bar and some flathead screwdrivers. I thought it would never come off...just keep trying
Old Jun 15, 2006 | 03:16 PM
LudemanDan's Avatar
I haven't taken one apart myself, but I read once that there's a bolt you have to take out having to do with reverse. It's some bolt that holds some component for the reverse gear. Figure out if that makes sense.
Old Jun 15, 2006 | 04:53 PM
shutta's Avatar
thanks ludemandan.. bb4 socal, i have it off the block, I didn't need to pry it, it just came apart itself.. I found my serice manual so that'll probably help a ton
Old Jun 15, 2006 | 05:22 PM
flyrod's Avatar
Default Re: (shutta)
Did you spread the clip on the bearing to the counter shaft? There is a port on the back of the tranny that you open to get at the clip. Please post up some pictures of what happened. I'm using an m2b4 also. If the tranny turns out to be messed up, but the 5th gear is ok, I would like to buy the 5th gear set from you. Good luck, and the helm manual should be a good guide to teardown.
Old Jun 15, 2006 | 06:24 PM
shutta's Avatar
thanks flyrod, i'll look into that tomorrow.. if I can get this tranny repaired, i'm cleaning it to a damn mirror shine
Old Jun 15, 2006 | 08:00 PM
Eddiebx's Avatar
did u take off the dust shield on the bottom of the tranny between the bellhosing and the oil pan?
Old Jun 16, 2006 | 12:13 AM
sparkx888's Avatar
It will come off sooner or later.. it will just take some time
Old Jun 16, 2006 | 12:28 AM
K-Spec's Avatar
try removing the tranny mount...and you are probably forgetting to loosen one of the bolts near the rear engine mount. You shouldn't have to pry it off at all, it's not like they put some type of sealant to begin with. The tranny is just being held by bolts.
Old Jun 16, 2006 | 04:14 AM
shutta's Avatar
i think some of you are being confused as to what i'm stuck on.. no big deal, I think I can figure it out
Old Jun 16, 2006 | 05:14 AM
flyrod's Avatar
I think shutta has the transmission out of the car already, he is now trying to open the transmission...
Old Jun 16, 2006 | 04:03 PM
shutta's Avatar
^^correct^^
Old Jun 16, 2006 | 04:53 PM
577HondaPrelude's Avatar
you need to get the clip ring off the main shaft bearing. Look for the big round cap on the very top of the tranny that a socket driver can fit into (square pit). This cap will come off then you need to remove the clip ring from the groove on the bearing. Look in your service manual, it's all in there.
Old Jun 16, 2006 | 07:30 PM
jdmlude_dude's Avatar
Default Re: (577HondaPrelude)
yeah more thank likely what is holding you up is the clip ring on the main bearing. the bell housing and the case is sealed with hondabond. so it takes some prying. just becareful, i have creaked cases doing that stuff.
Old Jun 16, 2006 | 07:41 PM
Rosko's Avatar
Default Re: (jdmlude_dude)
Shutta-
The clip at the top of shaft is the first thing that will hold you up, Youll see it if you take off the plugs in the end of the case.
Make sure the bolt for reverse is out.
Pull the shifter mechanism out as well as the ***** and springs that hold the shifter forks in place.
If you do all that then it should pull right off and the shifter forks will stay with the gears.
I've got an M2F4 right here all torn apart if you need any pics (shouldnt be much diff)
Old Jun 19, 2006 | 04:30 AM
flyrod's Avatar
Default Re: (Rosko)
any luck?
Old Jun 19, 2006 | 03:18 PM
shutta's Avatar
haven't had time, I've been running around like a madman lately.. My dad knows a good transmission guy who said he'd look at it for me so i'm probably not going to bother..
methos713
Oct 25, 2007 06:29 AM
sloaccord
Mar 23, 2005 10:31 PM
hybrid1990crx
Jul 24, 2004 07:17 PM
Tyson
Apr 22, 2004 06:20 PM
boomslang
Nov 2, 2001 06:21 AM
