Comptech Tie Bar/Sway Bar Combo
Old Jun 15, 2006 | 12:31 PM
99blackLS's Avatar
Default Comptech Tie Bar/Sway Bar Combo
I am thinkin of gettin the comptech tie bar/sway bar combo for my 99 teg and was wondering if anyways has this with aftermarket exhaust or know what aftermarket exhaust clears the comptech combo. i thought there was an old post about this but i couldnt find it :/ thanks
Old Jun 15, 2006 | 01:38 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Comptech Tie Bar/Sway Bar Combo (99blackLS)
hum, you could look through this thread and see if anyone has that setup
https://honda-tech.com/zerothread?id=1488656
Old Jun 15, 2006 | 02:42 PM
xdc2b18c1x's Avatar
usually any exhaust that goes over the LCA would work, exhaust such as HKS Hipower would not work because its goes under the LCA
Old Jun 15, 2006 | 03:03 PM
kchungb17a's Avatar
Default Re: Comptech Tie Bar/Sway Bar Combo (xdc2b18c1x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdc2b18c1x &raquo;</TD></TR><TR><TD CLASS="quote">usually any exhaust that goes over the LCA would work, exhaust such as HKS Hipower would not work because its goes under the LCA</TD></TR></TABLE>
huh???? Do you mean the piping runs under the LCA? Are you sure about that? I haven't seen the exhaust you're talking about, but if piping runs under the LCA, then you would have some serious ground clearance issues.... right?
Old Jun 15, 2006 | 03:17 PM
jweezy225's Avatar
Default Re: Comptech Tie Bar/Sway Bar Combo (kchungb17a)
im pretty sure the comtech combo is like the suspension techniques combo and im sure it clears certain aftermarkey exhausts... I happen to have an RS-R exmag exhaust, though
Old Jun 15, 2006 | 03:55 PM
gsr_racer_chick's Avatar
yeah i have the HKS and it goes under it and so far i havent had any issues with ground clearance
Old Jun 15, 2006 | 04:52 PM
kchungb17a's Avatar
Default Re: (gsr_racer_chick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_racer_chick &raquo;</TD></TR><TR><TD CLASS="quote">yeah i have the HKS and it goes under it and so far i havent had any issues with ground clearance</TD></TR></TABLE>
Wow, I gotta get out more often..... thanks for letting me know.
the comptech sway bar is adjustable. I believe it has 3 different settings. I think this is why they say it won't clear certain exhausts. I posted a similar post awhile back when I was looking into getting the setup, esp, since I have a twin loop muffler which takes up a lot of space under there. Nobody had any info on the matter, so I just opted to get the comptech lower tie bar only (which has a nice strong anti sway bar mount) and paired it with the USDM ITR rear bar. I just had to squeeze the D clamps for the sway bar mount just a bit with a pair of channel locks to get the bolt holes to line up. I sure woulda been upset if I had bought the complete comptech combo only to learn that it wouldn't have worked with my exhaust, so I didn't risk it.
I know, lots of words and no help... sorry.
Old Jun 15, 2006 | 06:58 PM
Dartanian's Avatar
I have the Comptech setup with a Greddy Evo2 exhaust and it has at least 2 inches of clearance.
Dr0d23
Acura TSX
May 26, 2008 10:29 PM
Chuck Dean
Suspension & Brakes
May 28, 2006 11:12 PM
jamartin0519
Sep 2, 2004 02:25 AM
civ98
Mar 27, 2004 02:14 PM
Dodger2940
Apr 30, 2002 02:42 PM
