Forbidden short shifter problem
Old Jun 15, 2006 | 10:35 AM
iLUVmyACCORD's Avatar
Default Forbidden short shifter problem
where is the screw that i use to put into the short shifter?
the stock shifter has the screw embedded on to it so there isnt a xtra one for the new shifter
Old Jun 15, 2006 | 10:45 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Forbidden short shifter problem (iLUVmyACCORD)
I think I remember reading that you need to go to Honda and buy the bolt. Contact Forbidden, I believe they can give you the exact part number you'll need.
Old Jun 15, 2006 | 10:52 AM
oh thanks.. i think ill just head over to honda now
Old Jun 15, 2006 | 10:55 AM
khunt0012's Avatar
Meat Robot Invisible
Default Re: Forbidden short shifter problem (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">I think I remember reading that you need to go to Honda and buy the bolt. Contact Forbidden, I believe they can give you the exact part number you'll need.</TD></TR></TABLE>
Not too sure about that. What year is the car?
H-T Order of Merit
Default Re: (iLUVmyACCORD)
If I remember correctly, I think you'll find it in the Prelude shifter diagram when you get to Honda. Just have the person at the parts counter pull up the diagram and show it to you, you should be able to locate it.
Old Jun 15, 2006 | 10:56 AM
H-T Order of Merit
Default Re: Forbidden short shifter problem (khunt0012)
I could of swore that the shifter where intended for the Prelude and if you where buying it for and Accord you would need to buy that bolt from Honda. I'll try and find where I read that at.
Old Jun 15, 2006 | 10:58 AM
khunt0012's Avatar
Default Re: (TouringAccord)
Correct sir:
90165-SS0-000 is the part #. It's #26.
Old Jun 15, 2006 | 10:59 AM
khunt0012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">I could of swore that the shifter where intended for the Prelude and if you where buying it for and Accord you would need to buy that bolt from Honda. I'll try and find where I read that at.</TD></TR></TABLE>
Yuo were right. I looked it up for an Accord which is wrong because the bolt actually is built into the Accord shifter.
Old Jun 15, 2006 | 11:03 AM
H-T Order of Merit
ok, thought I might be loosing my mind there for a second
I just went onto SLHonda and looked at the same diagram you posted because I couldn't find where i read it just to verify what I thought. Then I came back about to post the pictures but you beat me to it
Old Jun 15, 2006 | 11:05 AM
khunt0012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">ok, thought I might be loosing my mind there for a second
I just went onto SLHonda and looked at the same diagram you posted because I couldn't find where i read it just to verify what I thought. Then I came back about to post the pictures but you beat me to it </TD></TR></TABLE>
Haha, I use SLHonda too! I went all ninja on you there I guess.
Old Jun 15, 2006 | 11:15 AM
H-T Order of Merit
haha, I like SLHonda because their diagrams are clearer than Majestic (HAP).
Old Jun 15, 2006 | 04:41 PM
VHOA's Avatar
do they sell short shifters for automatics?
Old Jun 15, 2006 | 06:41 PM
fw190bvi's Avatar
Default Re: (VHOA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VHOA &raquo;</TD></TR><TR><TD CLASS="quote">do they sell short shifters for automatics?</TD></TR></TABLE>
no. there is not a "short shift kit", however upgraded torque conveters can give you faster shift times. A short shift kit only acts to decrease the "throw" of the shift lever to get from one gear to another. Usually this is done by changing where the linkages connect to the rod, and the overall length of the rod.
im confused....why can't you use your old accord bolt?
Old Jun 15, 2006 | 07:02 PM
sony224422's Avatar
Default Re: (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">
im confused....why can't you use your old accord bolt?</TD></TR></TABLE>
I think its because its built in.. atleast thats what i get from reading this.
Old Jun 15, 2006 | 09:18 PM
momstaxi's Avatar
Default Re: (sony224422)
yes, and it should be noted that you really dont need this exact bolt to do the shifter install. any 8mm threaded bolt and nut combo would do just fine...
Old Jun 15, 2006 | 09:23 PM
yeah its built into the oem shifter....
the one forbidden has is made for the prelude.. but it fits for the accord also.. so for all you who is gonna get one.. ill advise you to go to a dealership and order that bolt part first before you order your short shfiter from forbidden..
i was lucky enough to find something small and round to fit through the hole to make it work for the mean time.. heres what im talkin about..
its #26 on the diagram a few post up..
Old Jun 16, 2006 | 12:10 AM
raceACCORDingly's Avatar
you need the lude bolt and the little sleeve thing.
it doesnt feel right with a DIY sleeve and home depot bolt.
Old Jun 16, 2006 | 05:20 AM
H-T Order of Merit
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">you need the lude bolt and the little sleeve thing.
it doesnt feel right with a DIY sleeve and home depot bolt.</TD></TR></TABLE>
I've read that a couple times in other posts as well. Does it make it feel sloppy or something?
Also, iLUVmyACCORD, what year Accord are you putting this into?
Old Jun 16, 2006 | 06:35 AM
95 ex coupe.. ill take a picture of what i have holding it together at the moment...
im gonna try to describe it.. im sure you all have headphones.. im using the headphone jack extension that you would use to plug it into a home surround sound stereo ..
exactly as pictured..
Old Jun 16, 2006 | 06:52 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLUVmyACCORD &raquo;</TD></TR><TR><TD CLASS="quote">95 ex coupe..</TD></TR></TABLE>
Perfect
Would you mind doing something for me?
I was wondering if you could place the cable on the top setting and see if it hits anything like the console or just anything when you shift through the gears? Also, do you think you could place the cable in all three settings and descibe the difference in shift length and/or feel? And one last question, do you think you could take a picture of the final assembly so I can see where the shifter sits in the console, so I can see how much shorter it is from stock?
If you don't have time or if it's too much of a hassle, I understand. Those are just a few things I've been questioning but can't seem to find anything to answer them. If you could do that for me though I would really appreciate it.
Thanks
Old Jun 16, 2006 | 07:10 AM
honda4674's Avatar
(is it SLhonda.com or is it a different domain name)nevermind sorry great site though
Old Jun 16, 2006 | 07:25 AM
H-T Order of Merit
Default Re: (honda4674)
yeah, there are a couple online places like that where you can order parts from.
Majestic Honda (HAP)
San Leandro Honda
Old Jun 17, 2006 | 08:57 PM
ill try and try out all the holes out and take pics.. im getting the screw on monday from HONDA so.. ill do it then..
Old Jun 19, 2006 | 04:09 AM
H-T Order of Merit
that would be great, thanks
Old Jun 27, 2006 | 09:42 AM
H-T Order of Merit
Just wondering if you were able to get those pictures and try out the other cable positions when you replaced the screw?
