pm6 code?
ok well i got this 91 crx dx with a d15b7 in it and i think that is the dx motor for 92-95 civic,and when just barely push on the gas it feels like its cuttin out and then my check engine light comes on only when im drivin for awhile, but when i shut the car off and turn it back on it goes away anybody know what up? and how do i check to see what code im throwin?help a brotha out thnx
Turn the car on.
Wait until the light pauses.
Count each time it lights up until it pauses again.
The number of times it lights up will tell you the code number.
Search your code number.
Fix your problem.
Fix your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEK209 »</TD></TR><TR><TD CLASS="quote">my only prob is that the code only comes on when im drivin and if i shut the car off then turn the ingnition on its not there anymore</TD></TR></TABLE>
the Check Engine Light will go off every time you shut the ignition off but the codes will still be retained in the ECU until you reset it - turn ignition on and look at the LED on top of the ECU and count the flashes - unless it has been converted to OBD1 and then you will need to jumper it
some guy told me my intake mani isnt for this motor here is the pic http://i60.photobucket.com/alb...5.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmEK209 »</TD></TR><TR><TD CLASS="quote">some guy told me my intake mani isnt for this motor here is the pic http://i60.photobucket.com/alb...5.jpg</TD></TR></TABLE>
looks like D16A6 intake manifold to me
damn i still cant figure out why my car feels like its missing when i just touch the gas a little but when i punch it it seems ok its wierd cuz my 96civic dx with d16y7 was faster
Sounds like whoever did the swap didnt switch the wires on the TPS. When going DPFI to MPFI (like the swap you have), they need 2 wires need to be reversed, or else the resistance is telling the ECU your giving it full throttle at idle and idle (or close to it) at full throttle.
http://www.geocities.com/teampimports/fuelinj.html
http://www.angelfire.com/d20/h....html
