PARTS, PARTS, and mo' PARTS RSX-S, S2000, DC2, E46 sedan, and MISC
Old Jun 15, 2006 | 06:47 AM
Luder94's Avatar
Default PARTS, PARTS, and mo' PARTS RSX-S, S2000, DC2, E46 sedan, and MISC
Keep in mind, low-ballers are more than welcome (in fact, some of the various stuff in the "Misc." list will be given away for free).
Here are my lists:
<u>2002 RSX-S parts:</u>
Hatch carpet
black hatch cover (mesh)
black foam spare wheel cover
Dash with frame (includes climate control)
Rear plastic quarter window panels
Rear plastic arm rest/lower panels
door panels with window/lock switches
center console cover
rear lower hatch cover (middle piece)
OEM side skirts
Rear bumper cover
black plastic hatch cover (underside, three pieces (pillar covers, center wiper cover)
headliner
stock intake
full interior carpeting
SRS combo (steering wheel, airbags (driver and passenger), cable reel, and front seatbelts)
door sills (pair)
stock tail lights
driver side headlight (scuffed)
third brake light cover/mount
front and rear floor mats (stained)
visors(pair)
OEM front lip
gas door cover
owner's manual
door handles
windshield wiper motor (front and rear)/frame/mount
windshield wiper cover/cowling
cruise control unit
fuel rail
all rubber seals (door/hatch) and drain tubing
gas door release and cable
rear hatch release and latch
aluminum gas tank cover
rear seat catcher (pair)
front and rear foam bumper beam covers
front and rera bumper beams
center chassis beam/support (beefy)
hood release with attached cable
front bumper emblem
ALL wire harnesses (motor, interior, sensors, etc)
OEM gauge cluster (45k+ miles)
dual radiator fans
Mugen fan switch and thermostat
Bose spare wheel amp
glove box
upper and lower plastic steering wheel cover
OEM radio (with code)
interior fuse cover panel
interior srs cover panel
interior fuse box (no fuses)
dash switch box (with cruise button, sunroof switch, and mirror switch)
black dead pedal/foot rest cover
ash tray
various interior covers (corner pieces, fuel release cover
hood prop
hatch shocks
steering wheel staulk
interior door handles
ac condensor
rear speaker covers
e-brake cover
front plastic 12v socket cover
black front door mirror covers (interior)
passenger side a-pillar cover (interior)
pair of wire/brake line covers (for underside of car)
various metal frames/mounts/brackets
<u>S2000 parts list</u>
2000 Soft top and frame
Black plastic rear shoulder trim (x 3 sets), one set of trimmed brushes for hardtop (x2)
Striker and striker plates
black vinyl shift boot
black OEM mirrors
black radio door cover (full piece with vent trim)
--SOLD one rear AP1 exhaust tip
exhaust manifold gasket (x2)
center console 2-button trim (goes in place of the coin tray)
Oem bare roll hoops (pair)
exhaust manifold
top header heatshield (x2)(mounts to header)
cat converter (26k miles)
battery tray
OEM front stabilizer bar
OEM rear stabilizer bar
engine bay fuse box heat shield (x2)(black, no holes)
radiator shroud (x2)
black center console glove box with secret compartment cover (with holes for windscreen)
roll hoop covers (separated)
a-pillar covers
soft top boot plastic (5 pieces; two corner, one rear, one bottom, and one glove box cover)
One full SRS set up (steering wheel and airbag and reel, passenger side (minus cover), seatbelts (pair), SRS computer)
One steering wheel with Rick's "S" circular badge (black lettering on Silver back)
foam tool box tray (no damage)
Intake manifold elbow (OEM)
Rear AP1 (MY2000) tail lights (x2)
Engine bay fuse box (no fuses, no relays)
cruise control box
smoked orange OEM diffusers
OEM black trim corner knee pieces (covers on center tunnel)
EPS fuse box (no fuses, no relay)
soft top control box
ABS brake control box (ECU)
Rear Body exterior side trim (pair) (by trunk lid)
AP1 round hazard button
AP1 Soft top roof switch
plastic battery tray
Rubber roof bumpers (pair)(protects soft top from rubbing against hinge on frame)
Splash guards for front wheels
Dash board bezel (with cruise button)
Audio control (minus start button) (on black silver chrome trim)
HVAC controls (on black silver chrome trim)
Red door handles
OEM mirror glass (pair)
Steering wheel control stalk (windshield control, turn signal control)
Immobilizer trim and circuit pieces (by ignition)
Cruise control steering wheel control box
rear bumper license plate tail light
lower seat frame (rails, pans, plastic trim, etc.)
oil pan (x2)
Muz roof well mat
--SOLDrear rotors (pair)
rear upper control arms
rear lower control arms
soft top motors (pair)
rear subframe brace/diff mount
coil packs (set of 4, 26k miles)
under hood liner (fire retardant liner, new condition)
foam bumper liners (2 front, 1 rear)
black carpet (transmission tunnel cover)(cut)(free)
red trunk lid
trunk base cover (cut)
Rick's black and silver leather tunnel cover and shift boot
MY 2000 S2000 radio and 6 disc CD changer with all wiring, cover, and cage
starter
intake manifold
fuel rail
OEM injectors
door windows
water pump (x2)
ac pump
alternator
throttle body
windshiled washer tank
coolant overflow tank
tensioner bracket
thermostat housing
air pump
knock sensors (x2)
Polished valve cover
Autozone replacement battery
OEM Honda battery (off of a MY 2004)
door sill trim
driver side foot well plastic trim
S2000 AP1 headlights (new condition, all tabs, unopened, no bulbs or ballasts).
S2000 antennae mast
S2000 antenna (x2)
S2000 stubby antenna
<u>BMW e46 sedan parts</u>
OEM Stanley orange corner-blinker housings (pair)
19" Hamann HM2 wheels
Rieger front bumper cover (painted Ti Silver)
Rieger rear window wing add-on (painted Ti Silver)
OEM e46 M3 front fog lights with trim (trim is painted Ti Silver)
<u>DC2 parts list</u>
Skunk2 Exhaust with silencer
Mugen cat-back piping
rear seat covers
OEM ITR front strut bar (x2) &lt;---I have two to sell
OEM ITR rear hatch bar
1995 rear GSR taillights (need to be polished badly)
1995 hatch lid (ready for repaint)
OEM side skirts (pair and painted black)
OEM steering wheel with airbag
OEM passenger side airbag
Autometer dual gauge bezel insert
OEM power side mirrors (two pairs (one is painted burnt orange, the other lipstick red))
Spoon style mirrors (non-power, and one side is missing a mirror)
Spoon style power mirrors (have mirrors, but they need to be mounted)
black plastic center panel for hatch
JDM front CF hood VIS version 1
JDM front CF hood VIS version 2
JDM front bumper cover OEM-style (fiberglass, fit and finish is excellent...freshly painted black)
<u>Misc Parts list</u>
4th gen Prelude center cluster
4th gen Prelude interior wire harnesses (for cluster and fuse box)
Steel braided hose dress-up kit
Accord projector headlights (APC crap), but they are good for yanking out the projectors for an HID swap
various Autometer gauges (a/f and egt)
various VDO boost gauges
various OEM speakers
various Infinity Kappa component speakers
New Autozone battery for Civics/Integra/S2000
white faced, green illuminescence Integra gauge cluster
various Honda OEM CD or tape decks (S2000, Integra, etc.)
S2000 CD changer with plug and play harness, protective cage, and vinyl cover
universal halo light headlight kit
...more to be added.
Did I mention that low-ballers are welcome?
Please either post here or IM me for any questions. Also, I have MANY quality vouches if needed!
Old Jun 16, 2006 | 05:06 AM
Luder94's Avatar
Default Re: PARTS, PARTS, and mo' PARTS RSX-S, S2000, DC2, E46 sedan, and MISC (Luder94)
All PM's responded to.
Old May 27, 2012 | 11:18 AM
crxmissing's Avatar
Here are my lists:
Hatch carpet
OEM side skirts
Rear bumper cover
headliner
stock intake
door sills (pair)
stock tail lights
visors(pair)
OEM front lip
gas door cover
owner's manual
door handles
cruise control unit
fuel rail
front bumper emblem
dual radiator fans
glove box
ash tray
hood prop
hatch shocks
ac condensor
rear speaker covers
e-brake cover
black OEM mirrors
exhaust manifold
battery tray
a-pillar covers
cruise control box
Red door handles
oil pan (x2)
Muz roof well mat
red trunk lid
starter
intake manifold
fuel rail
OEM injectors
door windows
water pump (x2)
ac pump
alternator
throttle body
tensioner bracket
thermostat housing
air pump
knock sensors (x2)
door sill trim
S2000 antennae mast
S2000 antenna (x2)
rear seat covers
crxmissing's Avatar
Hey hit me up my email machov55@yahoo.com need few parts thanks
brettnahmann
Nov 27, 2012 05:20 PM
Luder94
Jun 29, 2006 09:56 AM
teknojiz
Apr 9, 2005 08:49 PM
