need help installing rear integra koni yellow adjustable shocks......
sup guys i need some help installing my rear koni yellow adjustable shocks.....i was able to put in the fronts with no problem but i'm dead stuck to how to install the rear here is a pix of the shocks i bought any help would be great.....and before u guys get on me yes i did use the search and found nothing to wat i need.....they had a write up on it but didn't explain how to install the rear and no pix was add so pretty lost....any help would be great thx.....o yeh my car is a 94 integra gsr
Modified by jdm0ua at 3:35 AM 6/15/2006
Try looking around on http://www.team-integra.net . I will try to find it, and will post it if I do.
Here they are:
http://www.team-integra.net/se...D=494
http://www.team-integra.net/se...=1025
Try to give us more specific questions so we can help you better.
Here they are:
I have a g2, but install should basically be the same.
Very Basic Instructions
Unbolt the 3 top mount(strut) bolts
Take out the lower shock mount bolt that attatches the shock to the lower control arm
Take out the rear lower control arm bolt, lower the LCA
Pull shock/strut assembly out.
Reverse for installation.
That's basically it, very easy 30 min swap if using right tools and have no seized lca bushings.
Read the posts that are ^ about the tools needed.
***edit, hopefully you know how to swap the parts over to the new shocks/again not hard to figure out***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sooo_slow »</TD></TR><TR><TD CLASS="quote">I have a g2, but install should basically be the same.
***edit, hopefully you know how to swap the parts over to the new shocks/again not hard to figure out***</TD></TR></TABLE>
well guys thx for all the input.....i just found out today that i had a set of jdm itr lca thats why the rear didn't fit right.....since i already bought the set of koni i'm just gonna go buy a set of stock integra gsr lca and bot it back on then it should work perfect.....thx again
