car shakes bad when braking hard?
this only happens when going fast and braking. is it that i need new brakes an alignment or what maybe a dumb question but the more i learn.
Don't do a brake conversion. Simply go to a performance shop and get KVR cross drilled rotors (get the treated aswell, it's like 20$ more) and then hawk brake pads, basic, for your car. It's what I have and I can stop from 120kmh to 0 alot faster then most other cars. It can be a bad thing (had a teg that bumpered me, but he broke his bodykit so I won).
i hope its not the tie rod ends, ball joints, or steering rack. that would suck damn i hope its a bushing or a bad joint or maybe warped rotors. ill check it out today and give an update.
Only when you brake? It's the brakes them, the vibration are the result of a of angled brake part ie. warped rotors, defective pads, seized caliper, seized sliders ect. If it was all the time especially on acceleration then I would check other stuff. But since it's only on braking, the ball joints, tires, steering rack are not culprits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cobra Tim »</TD></TR><TR><TD CLASS="quote">Could be tie rod ends, ball joints, or steering rack too. </TD></TR></TABLE>
brakes may be "warped" but its not the problem, just a symptom.
kim_2_da_chee
Feb 21, 2003 01:16 PM
