DA Brake conversion
Old Jun 14, 2006 | 10:21 PM
LoveOfMoney's Avatar
Default DA Brake conversion
i was wondering if the DA brakes would bolt right on my 89' crx fine? and if it does bolt on, would i need anything else?
Old Jun 15, 2006 | 08:49 AM
bump
Old Jun 15, 2006 | 09:49 AM
90civichbsi's Avatar
Default Re: (LoveOfMoney)
the fronts bolt up just fine, you will just need an alignment afterwards. id recommend at least getting the DA proportioning valve in if your gonna use those fronts
Old Jun 18, 2006 | 04:54 PM
quik question, will the rear disk breaks bolt up too?
Old Jun 18, 2006 | 04:56 PM
dr_latino999's Avatar
Yes sir, and if you have a hatch or sedan, you can also use the DA emergency brake cables. Remember though, only use the DA trailing arm, not the DA Rear LCAs.
Old Jun 18, 2006 | 07:39 PM
:thumbdown:'s Avatar
Default Re: DA Brake conversion (LoveOfMoney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">the fronts bolt up just fine, you will just need an alignment afterwards. id recommend at least getting the DA proportioning valve in if your gonna use those fronts</TD></TR></TABLE>
This is correct. Just remember to re-use the CRX upper and lower control arms, the tie rods, etc. Just use the DA knuckle/spindle and reuse all the CRX stuff. You will definitely need an alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Yes sir, and if you have a hatch or sedan, you can also use the DA emergency brake cables. Remember though, only use the DA trailing arm, not the DA Rear LCAs.</TD></TR></TABLE>
Josh T Toffee
Suspension & Brakes
Nov 12, 2014 08:36 PM
89ED
31
Jun 14, 2013 01:36 PM
JustHere4ADay
Jan 21, 2008 02:34 PM
hondaon18's
Jul 2, 2007 03:33 PM
gunmetalcivic
Oct 18, 2005 08:16 PM
