Idle adjustment
Old Jun 14, 2006 | 09:34 PM
NTGR8D's Avatar
Default Idle adjustment
I just threw in cams and valvetrain, and tried adjusting the idle using the screw on the TB like everyone says. However, when I disconnected the IAC, the car just stalls. I tried loosening the screw more and retrying to unplug the IAC without stall, however, I wasn't able to get the car to stay on.
So pretty much I have no way to adjusting the idle besides just adjusting the screw with the IAC on. did a search already and couldn't find anything useful. Did anyone else have this same problem?
Old Jun 14, 2006 | 10:43 PM
92TypeR's Avatar
FSAE
Default Re: Idle adjustment (NTGR8D)
Explain again why you are disconnecting the IACV?
Old Jun 14, 2006 | 11:02 PM
NTGR8D's Avatar
Default Re: Idle adjustment (92TypeR)
you are supposed to unplug the IAC when you are adjusting the idle speed.
Old Jun 15, 2006 | 09:01 PM
92TypeR's Avatar
FSAE
I have always adjusted idles w/the IACV connected.
What cams? If they have large primaries you will need to have fuel/ignition control at idle, ie: Crome, Hondata, AEM...etc
dc4b20
22
Dec 3, 2012 09:54 PM
Elvis1977
Apr 1, 2009 04:13 PM
dubman410
Apr 27, 2005 04:10 AM
slimbo
May 16, 2004 10:57 PM
