new clutch....keeps stalling
Old Jun 14, 2006 | 08:30 PM
blkrex's Avatar
Default new clutch....keeps stalling
it satlls when im in gear and i put the clutch pedal in...and hit the brake????? wtf
Old Jun 15, 2006 | 09:23 PM
Mavrick's Avatar
Default Re: new clutch....keeps stalling (blkrex)
sounds like an electrical issue from you brake lights is shorting out you ignition causing it to stall, that or an ultra weak alternator
Old Jun 15, 2006 | 10:01 PM
.Manny.'s Avatar
Touching My Member
check all the grounds
Old Jun 16, 2006 | 05:11 AM
crx_88_si's Avatar
what about if its in neutral.
Old Jun 16, 2006 | 10:55 AM
blkrex's Avatar
Default Re: (crx_88_si)
yah i juss pulled my tranny again lastnight...it was the throw out bearing fork looken thing......the bolt that held it down 2 clitch cable arm had broke off inside so the throwout bearing wasent reaching the preasurs plat.....but i still dont no y it wouldent stall in neutraul????
Old Jun 16, 2006 | 11:24 AM
nappyroots827's Avatar
Default Re: (blkrex)
cuz in neutral the gears aren't engaged, so even if the plate and flywheel are engaged, it still spins
mchappell90
Apr 17, 2014 07:10 AM
85camocivic
Transmission & Drivetrain
Mar 15, 2011 06:34 PM
TypeRod
Dec 1, 2010 06:26 PM
V-SPEC 1
May 19, 2007 07:45 PM
LSVtechnologytur...
Jun 25, 2005 08:54 AM
