whats the procees? plug or sniff?
Old Jun 14, 2006 | 06:36 PM
tthomass's Avatar
Default whats the procees? plug or sniff?
how are emissions done? i've been told they plug into your computer and i've been told they just hook up at your exhaust and use the sniffer
i've never had emissions
i've got a 99SI.........throwing code because my cat is gone
if i put the cat back, screw in my sensor that is zip tied under the car, clear the code at Advanced Auto...............will I be set? i've got stock exhaust, kami 4-1 header and password jdm intake........sounds good to pass to me?
Old Jun 14, 2006 | 06:46 PM
Slamaccord's Avatar
Default Re: whats the procees? plug or sniff? (tthomass)
Emmisions are regulated differently throughout the states.
Throw on the cat and clear the code. Drive it around for while to make sure the code doesn't come back. Take it to inspection. Just use your stock exhaust it will benefit you, when it comes to the inspector judging your car. They seem to look harder on modded
exhaust cars.
Old Jun 14, 2006 | 06:58 PM
tthomass's Avatar
Default Re: whats the procees? plug or sniff? (Slamaccord)
yeah its stock on there..........N1 was too loud
Old Jun 14, 2006 | 07:02 PM
Slamaccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthomass &raquo;</TD></TR><TR><TD CLASS="quote">yeah its stock on there..........N1 was too loud </TD></TR></TABLE>
Lol I don't think you wanna even try with a N1.
Old Jun 15, 2006 | 05:13 PM
tthomass's Avatar
nobody gets emissions in VA?
Old Jun 15, 2006 | 07:25 PM
jdeemseerx's Avatar
ob2 inspections are done through the connector under the dash while the car is running the computer does the rest..obd1 and earlier are done on the dyno with a machine that is hooked to your exhaust
Old Jun 15, 2006 | 07:43 PM
EX-T's Avatar
Default Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">ob2 inspections are done through the connector under the dash while the car is running the computer does the rest..obd1 and earlier are done on the dyno with a machine that is hooked to your exhaust</TD></TR></TABLE>
Yeah, what he said only here in TN they don't put our cars on a dyno. They just stick the sniffer in the tail pipe on pre 96 vehicles
Old Jun 16, 2006 | 07:18 PM
tthomass's Avatar
Default Re: (EX-T)
so if i just go clear my codes at Advance Auto they won't see anything right? i'm gonna go ahead and get a cat as soon as i can find one
Old Jun 16, 2006 | 07:25 PM
Syndacate's Avatar
I'm pretty sure the cops use the sniffer b/c it's pretty portable (err that might be the decibal tester), but I'm pretty sure it varies from garage to garage, b/c I've seen ones at a garage called D&R by me and they don't have a sniffer, they hook it up to the computer..but like when u either rebuild salvage or build ur own car up and have to get it salvage build title and they assign it a vin # and such I've seen 'em use sniffers there....so I tink it varies :-\
Old Jun 16, 2006 | 10:25 PM
jdeemseerx's Avatar
dont clear the code until you get a cat..once you put the cat in then clear the code drive around for at least a week so the code is not in the ecu memory and then youll pass
justdoinme23
Jun 15, 2011 06:43 AM
tcbbandman
Jan 25, 2011 01:17 PM
transitions
Aug 15, 2005 01:12 PM
LillDragun
Jul 11, 2002 05:47 PM
