uce question never asl before i bet money
Old Jun 14, 2006 | 04:22 PM
JJ's civic's Avatar
Default ecu question never ask before i bet money
do you guys think i would save gas using a pm9 evu out of a std civic in replacemnet of a pm5?
Old Jun 14, 2006 | 04:37 PM
STREETWERKZ's Avatar
Default Re: ecu question never ask before i bet money (joeny12985)
try it.
ask someone that chips ECUs to look at the fuel maps. that's your best bet.
Old Jun 14, 2006 | 05:10 PM
JJ's civic's Avatar
Default Re: ecu question never ask before i bet money (STREETWERKZ)
anyone knwo where i can look at fuel maps? or can anyone let me know if i would save on gas?
Old Jun 14, 2006 | 05:14 PM
Rywire's Avatar
pm9 is hf, pm5 is dx.... its not plug and play... you need a dpfi to mpfi conversion
Old Jun 14, 2006 | 05:20 PM
JJ's civic's Avatar
Default Re: ecu question never ask before i bet money (droppedcrxsi)
no pm9 is not just hf i took it out of my std civic and jsut plug it in my sx civic and my civic is running no codes and i was wondering if anyone know if i would get better gas mileage with the pm9 out of my std then i would with a pm5 stock in the dx
i thought the pm9 was from the STD hatchback.
pm5 was from the DX. both dpfi.
Old Jun 14, 2006 | 05:25 PM
JJ's civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">i thought the pm9 was from the STD hatchback.
pm5 was from the DX. both dpfi. </TD></TR></TABLE>
that is corect if they are for anything else i do not know but i took the pm9 out of my std hatch and put it in replace of the pm5 in my dx wnating to knwo if i would save gas or not?
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">pm9 is hf, pm5 is dx.... its not plug and play... you need a dpfi to mpfi conversion</TD></TR></TABLE>
isn't a HF a pm8?
Old Jun 14, 2006 | 05:27 PM
JJ's civic's Avatar
Default Re: ecu question never ask before i bet money (Mr_CRX)
that i do not know does anyone know the fuel maps of the ecus?
Old Jun 14, 2006 | 05:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">
isn't a HF a pm8?</TD></TR></TABLE>
uh ohhhh. rywire needs to brush up on his ecu homework.
Old Jun 14, 2006 | 07:03 PM
Rywire's Avatar
LOL, pm8, pm9, whatever, hahahha Good catch guys. Why would the std have a different ecu than a dx civic? Isnt it the same eng?? Goes to show how much I know about these motors in stock form
Old Jun 14, 2006 | 07:12 PM
user 72830283's Avatar
speaking of which....is it possible to make an HF ecu+motor run in a DX chassis....provided i performe the needed MPFI change over? i mena is it possible...i'll probably post a thread regarding this sooner or later..i have some other HF questions i need answered...but for now is that possible?
Old Jun 14, 2006 | 07:28 PM
Rywire's Avatar
Default Re: (pr3d)
sure, the pinouts are almost the same as the si
Old Jun 14, 2006 | 07:54 PM
JJ's civic's Avatar
Default Re: (droppedcrxsi)
i put the pm9 in my dx which had a pm5 with no prob at all direct plug and play. and the differnce is that the std as a 4 speed the dx has the 5 spd. well that's the only diffence in my. my std has a d15b2 in ti when i bought it
Old Jun 15, 2006 | 02:30 AM
JJ's civic's Avatar
Default Re: (joeny12985)
bump
Old Jun 15, 2006 | 05:08 PM
JJ's civic's Avatar
bump
Old Jun 19, 2006 | 03:46 PM
JJ's civic's Avatar
arite i pull the pm9 out. it felt like i had more power but i was using way to much gas. plus the pm5 as enough power for me and it uses far less gas. not worth the power gain if any. could jsut be i was more on the gas but i tryed not to be because i'm broke this week for gas money and i NEED to get to work.
well that's what got from putting a pm9 into my dx in replacement of my pm5
gb73
Honda Civic (2006 - 2015)
Nov 2, 2007 09:24 PM
Fusion G2 Civic
Jun 24, 2006 03:32 PM
jebbio24
Jun 21, 2006 02:14 PM
spaceman00
May 12, 2006 11:07 AM
J_J
26
Jan 8, 2005 06:04 AM
