how do i know when its time to change the timing belt
Old Jun 14, 2006 | 02:23 PM
vivaladan89's Avatar
Default how do i know when its time to change the timing belt
ok well heres the thing, my car makes a noise while its running... ive never heard an engine sound like this especially honda considering they r usually quite. it sounds like something is rotating against something.
here is a video of the engine and the sound its making, takin with my digi cam so quility isnt perfect...
http://www.youtube.com/watch?v=oRkrLypXWZI
also this is a 98 accord coupe v6 auto, has a lil over 98k miles on it.
Old Jun 14, 2006 | 03:15 PM
khunt0012's Avatar
Meat Robot Invisible
Default Re: how do i know when its time to change the timing belt (vivaladan89)
Well Honda recommends that you replace your timing belt every 100,000 km (or Every 60,000 km for you US folk).
As for that noise, not really sure what that is to be honest with you. It's a little tough to distiguish what it acutally is and where it's coming from. However, you are right in that it is not a normal noise.
Old Jun 14, 2006 | 06:51 PM
bump... would like some other opinions.
Old Jun 14, 2006 | 07:29 PM
philadd's Avatar
Default Re: (vivaladan89)
I can't tell where the noise is coming from, so I can't help you with that. If you can narrow it down to a smaller section of the engine bay, that might help.
As for the timing belt, you're due to have it changed. Change it based on Honda's recommendations.
Old Jun 14, 2006 | 09:11 PM
what does a timing belt usually run to get changed?
Old Jun 15, 2006 | 03:52 AM
khunt0012's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivaladan89 &raquo;</TD></TR><TR><TD CLASS="quote">what does a timing belt usually run to get changed?</TD></TR></TABLE>
Far too much.
I know most I4 cars that I used to do at Acura were somewhere in the range of 1000-1500$, but that was a full 100,000 km service. Timing belt, WP, t-stat, etc. Labour is the worst part of this job as they charge you up the ***. If you know somebody who you have confidence in to do somethign like this, you may want to have a chat with them.
Old Jun 15, 2006 | 06:35 AM
H22CD's Avatar
Ask the previous owner if the timing belt was changed at 60k. If not, you might want to go ahead and change it anyways. I got my car at 128k and the previous owner did'nt change the t-belt and it sounded similiar to that. But I'll tell you this, after I got the t-belt, WP, and all the basics, the car ran really quiet. And yes the cost was ridiculous. I shelled out 1000+ at my local Honda dealership.
Old Jun 15, 2006 | 07:30 AM
ricebike's Avatar
wow, i thought i paid too much for labor-only @ my local honda dealer... $525 (i previously bought OEM parts, but didn't have all tools to do it correctly myself)
http://www.troublecodes.net/tbelt/hondatb.shtml is another good resource
Old Jun 15, 2006 | 10:31 AM
devilpuppy's Avatar
okay i'm not too sure if mines been changed or when it was changed
is there any way to check, or any symptons i should be seeing
Old Jun 15, 2006 | 04:11 PM
hondadude's Avatar
Default Re: (devilpuppy)
The first 'symptom' you'll have of a shelled T-belt will be the car quits running; the second symptom will be all your money going into someone elses hand to fix the problem. It's the classic "stingy man pays the most" syndrom.
Replace the T-Belt and be done with it.
Old Jun 15, 2006 | 04:23 PM
VHOA's Avatar
when it breaks and ***** up your engine i would change it
Old Jun 15, 2006 | 05:33 PM
cats_on_ice's Avatar
Default Re: (VHOA)
That would be too late. MUCH too late, don't go there.
Most honda engines are interference fit. Which means that for a certain % of the time, the valves occupy space that the pistons will soon (VERY) occupy. I THINK my f22 is like a 30% interference-fit engine... or something. But that's probably so far off it's funny.
So, if your timing belt were to kick the bucket, the pistons will, most likely (99.99% gauranteed?), SMACKSMACKSMACKSMACKSMACK into the valves.
Yes you SHOULD lose sleep over this idea. I know I do. Damn used cars. So much drama!
ZurEnArrh
Jan 11, 2018 11:07 AM
jonathancbrewer
Sep 24, 2016 05:34 AM
chancekang
Apr 23, 2011 03:28 PM
nfinite
Dec 6, 2008 12:11 PM
Sunshine42
Sep 5, 2007 07:30 AM
