EG6 cluster bulb size
https://honda-tech.com/zerothread?id=661308
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">You also need to go to your local pep boys and get five #24 automotive bulbs (they come in 2-pack, so you’ll get six) and also three #74 bulbs. The cluster takes five #24’s and one #74, and the climate control takes two #74’s. Take a piece of scotch tape and wrap it around the bottom to make sure you don’t get any paint on the connectors. I used several coats, but you can use as many or as few as you want. I let them dry overnight, to make sure that they were nice and dry.
Or go to a junkyard and take out a random Civic cluster and pull the bulbs out. Thats what I did lol
Note: The JDM Sir bulbs are different size. The bulbs that light up the backround of the cluster that is. In the USDM clusters they are 24s, and the jdm ones are slightly smaller. However, you can still use the 24s, they will fit fine through the holes. The other bulbs are the same size and are interchangeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Note: The JDM Sir bulbs are different size. The bulbs that light up the backround of the cluster that is. In the USDM clusters they are 24s, and the jdm ones are slightly smaller. However, you can still use the 24s, they will fit fine through the holes. The other bulbs are the same size and are interchangeable.
Never knew this. Is this the same for the VTi clusters as well?
</TD></TR></TABLE>Never knew this. Is this the same for the VTi clusters as well?
goldenmustache
Apr 15, 2009 04:11 PM
