si transmission question
Old Jun 14, 2006 | 09:20 AM
bigwill_2004's Avatar
Default si transmission question
how do u exactly know if u have an si trans? since all the trans.(88-91) are L3's and interchangable. but they're are numbers after the L3, mine is labeled L3 1196957, anyone know which one it is?, the reason i ask is because i have an 88 crx hf with si engine (d16a6) and tryin to see if it is also the si trans. please help.thx
Old Jun 14, 2006 | 09:36 AM
xDicktonesx's Avatar
Default Re: si transmission question (bigwill_2004)
bump...and i want to know if the SI and DX trannies ratios are really that different
Old Jun 14, 2006 | 09:40 AM
jlicrx's Avatar
Old Jun 14, 2006 | 09:43 AM
Targa250R's Avatar
be professional
If the transmission is off the car, open the case and start counting gear teeth. Or do this: http://www.norcalcrx.org/tyson...1.jpg (link from the FAQ sticky; thanks to Tyson)
If the transmission is on the car and it is driveable, you can easily tell which transmission you have by comparing the reading ratios of the speedometer and tachometer in 5th gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDEFTONESx &raquo;</TD></TR><TR><TD CLASS="quote">bump...and i want to know if the SI and DX trannies ratios are really that different</TD></TR></TABLE>
The individual gears all have the same ratios for DX and Si, but the Si final drive is much shorter (about 10%).
Old Jun 14, 2006 | 10:04 AM
jlicrx's Avatar
Default Re: si transmission question (xDEFTONESx)
Old Jun 14, 2006 | 01:58 PM
Default Re: si transmission question (jlicrx)
appreciate it peeps
Dragon07SI
K Series
Jun 9, 2017 06:44 AM
ef-hatchcrap
Aug 10, 2009 01:05 PM
crazy sohc vtec guy
11
Jul 10, 2008 02:29 PM
maximedx
Mar 1, 2003 12:32 PM
MOCrxHf
Jan 19, 2003 10:11 PM
