1995 Civic Hatch NY - LS/VTEC - JDM parts
<FONT SIZE="8">$6500!!! obo </FONT>
Car is Located in 845 NY
Testing waters on my lovely Civic again...Heres the list...
Engine:
-B18A1 block decked and resurfaced
-All bearings/seals/rings BRAND NEW
-All surfaces resurfaces (rod/crank journals, bearing surfaces, etc) Reciepts for all machinework are here with me.
-B18B1 Rods
-Spoon Sports balanced JDM ITR Pistons (11.7cr in this combo)
-ARP Main studs
-ARP rod bolts
--ARP Head studs
-OEM LS Head gasket
-Greddy oil filter adapter
-Russel -6 VTEC Line
-All Russell fittings
--JAZ mini Catch can with OEM prelude block fittings for sirect PCV vent. Braided PVC hose.
Head:
-B16A Head milled .010"
-2001 JDM ITR Lost motion assemblys
-1998 US ITR Cams
-Stock valvetrain
-Wrinkle red valve cover
-ITR Chrome grommet set.
-B16A2 Intake Manifold
Transmission:
-2000 GSR Transmission
-Exedy Stage 1 race clutch
-ACT 12lb flywheel
-ARP Pressure plate bolts
-New OEM flywheel bolts
Other Engine Mods :
-Innovative Urethane Street mount kit
-Apexi Worldsport 2 exhaust
-OmniPower 2.5" Test pipe
-Chipped P28 from Pherable.net
-Apexi VAFC1
-AEM fuel Rail
-Earls SS Braided fuel feed line
-Autometer FPR
-AEM 2 3/4" Cold Air
-JDM ITR 4-1 Header with Heat shield (Not smacked up either)
The car has pretty much brand new everything. Water pump, Timing belt, starter, alternator, battery...etc...
Mileage one the whole motor is 2900miles!!! This is a very fresh motor with very little mileage on it. All it needs is a good tune
Body:
-Harvard blue original color
-JDMshit Duckbill
-JDMshit 'type r style' lip
-Vision corners
-Spoon style mirrors
-VIS cf hood (VERY VERY clean and may not sell with hood)
-Auto ventshade wind visors (may need new tape soon)
Wheels/Tire
-15 mint Rota C8's bronze
-205/50/15 Falken Ziex (front needs replacement soon)
Suspension/brakes
-KYB GR2 Shocks
-Ground control 400f/450r
-Rear Ingals camber kit
-Earls SS brake lines all around
will include GSR strut tower brace
Interior
-1996 Integra LS front seats (very clean)
-1992 CX black vinyl rear seats (very rare and clean)
-JDM Amber clock
-JDM Climate control
-JDM SIR Cluster (Amber lit white face)
-Brand new OEM ITR Shifter
-2002 civic Si shift **** (black leather/red stitch)
-Pioneer 6" front speakers
-Sony (i think) cd deck
-Gray hatch cover (clean)
Car is pretty clean inside and out. Ive owned it for 3 1/2 years. This new motor has never given me a problem yet. Ive never dynoed it or ran the car at the track. It does pull strong, but I do not beat on it due to the lack of a tune. The oil has been changed every 500 miles using Genuine Honda oil and filters.
The Bad
-Minor Quarter rust on both sides. Very fixable
-Back bumper has a scratch across it, but many have never noticed it bc it blends in with the color so well. No biggie.
-Moldings are a bit faded, but thats not even bad.
-May need a passenger side axleshaft. It was vibrating a tad when the swap went in. Changed the axle with another, and the vibration seems to be going away.
-Oil pan gasket leaks slightly around the flywheel side. Very small leak. New OEM gasket will be supplied to buyer.
Im open to all trade offers, but lets keep it reasonable. Im looking for a newer EK hatch. Got one? We'll talk... I put a lot of time and a Whole lot of money into this car. I spend around 3900 on the motor itself between the parts and the machine work.
The car needs a good tune and thats all. It has a very conservative base map on it, so you could drive it hard with no problems if you wanted to, i just chose not to.
Here are some Pictures for reference.
Im probably leaving parts out as well, if I remember anything, ill post it up
Modified by NAisBEST at 7:25 AM 6/15/2006
Modified by NAisBEST at 12:36 PM 6/20/2006
Modified by NAisBEST at 1:13 PM 6/29/2006
Modified by NAisBEST at 2:46 PM 7/8/2006
Modified by NAisBEST at 4:34 PM 7/19/2006
Engine:
-B18B1 Rods
-ARP Main studs
-ARP rod bolts
--ARP Head studs
-OEM LS Head gasket
Head:
-1998 US ITR Cams
-Stock valvetrain
Transmission:
-ACT 12lb flywheel
Other Engine Mods :
-Apexi VAFC1
-AEM fuel Rail
-Autometer FPR
Body:
-JDMshit Duckbill
-Vision corners
Wheels/Tire
Suspension/brakes
-KYB GR2 Shocks
Interior
-JDM Amber clock
The Bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NY-GSR »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_JDM_EG2 »</TD></TR><TR><TD CLASS="quote">bump for a clean car...seen it in person...and a bump for vinny</TD></TR></TABLE>
thanks sir...
buy it up!
thanks sir...
buy it up!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAisBEST »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvervlll »</TD></TR><TR><TD CLASS="quote">up for vin these fireworks we got are sickkkkk
buy this car noww
lol, hells yeah they are...
SOMEONE MAKE AN OFFER!
buy this car noww
</TD></TR></TABLE>lol, hells yeah they are...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irishone »</TD></TR><TR><TD CLASS="quote">bump for a fellow 845'r</TD></TR></TABLE>\
thanks!
UP
thanks!
UP
