searched and need a lil more help.. 88std /z6 motor
Old Jun 14, 2006 | 04:02 AM
iTe4LIFe's Avatar
Default searched and need a lil more help.. 88std /z6 motor
I have an old 88 std hatch (4spd trans). First, I was going to mini-me it and now i've decided to change things up a little.
I currently have :
z6 head and intake manifold (complete with all bells and whistles) and po6 non vtec manual ecu. (total spent =$175)
I've decided instead of using the 1.5 block which probably could'nt go up to 6k rpms Why not use a z6 (i can get a z6 block for $50)
so would this work...?
z6 block/head/intake manifold
88 std L3 4 speed trans (using an 88 clutch/flywheel on the z6 block)
z6 ex distributor (im a little confused here.. )
po6 non vtec ecu (i plan on chipping it/ if i can add vtec activation with chipping then i'll do it; if not, i'll prob use an rpm switch)
z6 exhaust manifold (currently on the b1 head in the car)
and i still need to get an o2 sensor and plugs for my harness conversion (i've got no problem re-wireing my car and making my own harnesses).
the distributor... could i use a non vtec 92-95 41u? or would i have to get a vtec 42u?
i havent really came across any dizzys with low prices... i'll prob end up getting a newish off of ebay for around $100. if anyone has one i can use... pm, im or e-mail me!!
a little help is much appreciated (considering i prob wont buy a 95 to 00 until next year)!!
Old Jun 16, 2006 | 04:27 PM
iTe4LIFe's Avatar
TTT
Old Jun 16, 2006 | 04:40 PM
SVOboy's Avatar
Okay, you need the z6 dizzy and to convert to obd1, because other dizzies won't mount to the z6 head. Vtec/nonvtec doesn't matter on the dizzy, just the mounting, but you basically need to use either a z6 or z1 dizzy and convert to obd1 and use a p28 or chipped vtec p06 (yes, you can add vtec).
Old Jun 16, 2006 | 05:05 PM
pinecone's Avatar
Default Re: (SVOboy)
Yes you need a TD-42U and for the love of god don't do a rpm acitvated thing. Chip the P06.
You won't get anywhere the potential of the motor using the STD tranny w/ only 4 gears. Its geared for gas mileage and not performance. Try and find a SI tranny if you can.
Old Jun 16, 2006 | 05:09 PM
SVOboy's Avatar
Man, the std tranny isn't gear for anything besides cheapness, it has terrible high speed rpms,
rollinhonda3
12
Nov 11, 2010 02:48 PM
Edwin JDMJUNKIE
Dec 23, 2009 08:13 PM
FBEF20
Aug 7, 2006 10:00 PM
