Crx obd0 ecu prob
Old Jun 13, 2006 | 10:39 PM
Jdmcrx90hf's Avatar
Default Crx obd0 ecu prob
I have an obd0 jdm b16a swap. I finally got it running right, and i have used this ecu before on the last swap i did with a friend, and it has no rev limit, no governor etc. Vtec supposed to kick it at 4500. But it doesnt kick in. and also it wont let me go past 7k rpm??. When i was doin the swap, my lil brother mixxed up the positive and grounds and touch the positive the grounds a couple times creatin a big spark. Now could that have damaged the ecu, or any other sensors?? and causing this/?? help if you know anything would be helpfull THNX ALL for helpin me with my other probs!!
Old Jun 13, 2006 | 10:41 PM
SiR Inspired ED7's Avatar
Default Re: Crx obd0 ecu prob (Jdmcrx90hf)
check engine light on?
Does gauge cluster work properly?
Old Jun 13, 2006 | 10:42 PM
Jdmcrx90hf's Avatar
Default Re: Crx obd0 ecu prob (SiR Inspired ED7)
yea, everythin works in the cluster. Speedometer and rpm gauge. What would cause the rev limit when the ecu donesnt have one?? also no check engine light??
Old Jun 13, 2006 | 10:49 PM
Take off the ground to the battery for about 5 seconds and put it back on. let me know if it still does the same thing.
Old Jun 13, 2006 | 10:53 PM
Jdmcrx90hf's Avatar
i disconected the battery for 30 secs, ( a friend told me it would reset the ecu) and it still did that. Would disconectin the battery and disconectin the ground would make a difference??
Old Jun 13, 2006 | 10:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmcrx90hf &raquo;</TD></TR><TR><TD CLASS="quote">i disconected the battery for 30 secs, ( a friend told me it would reset the ecu) and it still did that. Would disconectin the battery and disconectin the ground would make a difference??</TD></TR></TABLE>
pretty much the same thing it resets the ecu. on the ecu is there a red light flashing or on?
Old Jun 13, 2006 | 11:18 PM
Jdmcrx90hf's Avatar
i will check for that tommorow, i havent checked. Thnx for the fast reply
Old Jun 14, 2006 | 01:06 AM
salman's Avatar
check for the VSS,. this is usually Happen due to bad VSS. when the ECu dont get proper signal form the ecu thing like this happens. Results in No Vtec plus liiter comes down to 7500
Old Jun 14, 2006 | 01:01 PM
Jdmcrx90hf's Avatar
Default Re: (salman)
vss is working fine, cuzz my speedometer reads fine....?? it wasnt working when i first did the swap, but once i noticed it i pulled the speedometer cable and put it back in down the tranny and now it works fine.......but could that have put the ecu into limp mode?? i also checked for a red light by the ecu, and i didnt see any. Any suggestions???
Modified by Jdmcrx90hf at 2:33 PM 6/14/2006
Old Jun 14, 2006 | 02:52 PM
DOHC_C-REX's Avatar
Default Re: (Jdmcrx90hf)
are you 100% on your firing order? timing? when it gets to 7k is it just a complete wall like you hit redline? or is does it sputter to get to 7k and not go any further?
and the "red light" is actually on the ecu itself...not by the ecu...
try another KNOWN good ecu...do not assume yours in fine....
if its a chipped ecu (and you say it is) it is very easy for one to malfunction
Old Jun 14, 2006 | 08:14 PM
Jdmcrx90hf's Avatar
Default Re: (DOHC_C-REX)
Its like a red line limit, you see on stock cars when you go on the red line its just doenst let you go over the set limit thats what it does. On the timing and firing order im pretty 99.9 sure thats its set and done right. About the red light i didnt see one on the ecu. Also when i turn the key, the cel never comes one before the car starts. And now that i come to think of it, it has never come on??? Maybe the light is burned out?? or not hooked up correctly on the ecu??. Thnx for the replys!!
Old Jun 14, 2006 | 08:43 PM
DOHC_C-REX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmcrx90hf &raquo;</TD></TR><TR><TD CLASS="quote">Its like a red line limit, you see on stock cars when you go on the red line its just doenst let you go over the set limit thats what it does. On the timing and firing order im pretty 99.9 sure thats its set and done right. About the red light i didnt see one on the ecu. Also when i turn the key, the cel never comes one before the car starts. And now that i come to think of it, it has never come on??? Maybe the light is burned out?? or not hooked up correctly on the ecu??. Thnx for the replys!! </TD></TR></TABLE>
the light is directly in the center of the ecu... you cant miss it... the light is supposed to come on when you turn the key to the on position...
Old Jun 14, 2006 | 09:40 PM
Jdmcrx90hf's Avatar
It was a code 6. Coolant temp sender on the block wasnt cliped on all the way. I hit Vtec YAY
Old Jun 15, 2006 | 03:42 PM
DOHC_C-REX's Avatar
doesnt it really make your day when its just stupid stuff like that?
Old Jun 15, 2006 | 09:08 PM
Jdmcrx90hf's Avatar
Default Re: Crx obd0 ecu prob (DOHC_C-REX)
thnx man i didnt think i was throwin a code cuzz there was no cel light. But yea, it was frustrating at first.......but now vtec hits hard
itzyaboyzeem03
Aug 16, 2008 02:41 PM
MtxWrl
May 8, 2008 04:08 AM
iNDyCRX
Feb 20, 2008 09:13 PM
