d16 head studs on d15?
Old Jun 13, 2006 | 08:33 PM
Hella_Fresh's Avatar
Default d16 head studs on d15?
i have a 90 dx motor and am going to do a mini me swap with turbo. and i was wondering if theres a way i could put the d16 arp head studs on the d15.
anyone know? or know of a solution?
Old Jun 14, 2006 | 10:01 AM
teal_dx's Avatar
Default Re: d16 head studs on d15? (sXekid)
I used D16z6 ARP's on my D15b7. Only 8 out of the 10 studs fit. Both of the outside holes on the back row wouldn't go in so I had to use OEM headbolts for those holes. This was for a D16y8 head on a D15b7 block, so your results could vary....
Old Jun 14, 2006 | 10:36 AM
peiku's Avatar
Default Re: d16 head studs on d15? (teal_dx)
really? i've used new honda d16z6 head bolts on my brothers dx coupe. they fit fine with no problems. maybe you just need to get your threads cleaned out.
Old Jun 14, 2006 | 06:10 PM
Default Re: d16 head studs on d15? (peiku)
oh see im going to use them on a 90 dx motor.
Old Jun 14, 2006 | 06:54 PM
peiku's Avatar
all 88-95 dseries use the same studs and bolts. as long as you are using any 88-95 head, they will work.
Old Jun 14, 2006 | 07:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku &raquo;</TD></TR><TR><TD CLASS="quote">all 88-95 dseries use the same studs and bolts. as long as you are using any 88-95 head, they will work.</TD></TR></TABLE>
hmm are you sure? because i have been told that the 92 and up d series heads are slight different
Old Jun 16, 2006 | 07:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sXekid &raquo;</TD></TR><TR><TD CLASS="quote">
hmm are you sure? because i have been told that the 92 and up d series heads are slight different</TD></TR></TABLE>
Old Jun 17, 2006 | 05:10 AM
peiku's Avatar
yes i am sure. i have done a mini-me before with an a6 block and a z6 head. i used z6 headstuds.
Old Jun 17, 2006 | 10:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku &raquo;</TD></TR><TR><TD CLASS="quote">yes i am sure. i have done a mini-me before with an a6 block and a z6 head. i used z6 headstuds.</TD></TR></TABLE>
sweet! thanks man
civicboy420
Sep 2, 2011 04:31 PM
i_shift
Jun 12, 2006 07:33 AM
19civiclx95
Dec 7, 2005 10:10 AM
jjaskula1
Mar 20, 2005 08:04 PM
delslo93
Dec 19, 2004 06:10 PM
