99-00 civic si
will a wire harness from a 99-00 civic si work with my b16a engine swap into my 96 civic ex? will everything wire up? and i dont have the wireharness that came with the car since it got stripped and stolen..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatch4sale »</TD></TR><TR><TD CLASS="quote">you can use it but you wont have a speedo </TD></TR></TABLE>
?? what part of your *** did you pull that out of?
the plugs are the same, even the cluster plugs are.
Too funny. Vero is right on the ball on this one.
it's the same harness! same wires, same plugs.
only the the ECU plugs are different for the different generation OBD2s
as long as your motor is OBD2, it's gonna plug right the flip in.
that is an OBD1 ECU.
you need to either obtain a jumper harness, repin the ecu plugs or get the P2T ECU from a 99-00 OBD2B Civic Si
Your Civic EX is an OBD2A which used a P2P, you had to modify that harness or get a jumper in order for it to work with a P30
christ, this is all covered by searching.
https://honda-tech.com/zerothread?id=810101
bluntly speaking. The 99-00 Civic Si harness is the exact same harness as the 96 Ex.
just use your 96 harness extend the two wires you need for the vtec get your obd2a-1 conversion harness that will save you so much more money than trying to get a si harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00MRBuilt »</TD></TR><TR><TD CLASS="quote">just use your 96 harness extend the two wires you need for the vtec get your obd2a-1 conversion harness that will save you so much more money than trying to get a si harness.</TD></TR></TABLE>
1) if you read, he said his ex harness was stolen
2) you dont have to extend or add wires to the EX harness, it has vtec prewired (vtec motor equiped
3) if'ts the same harness as the Si. identical.
)3) if'ts the same harness as the Si. identical.
i have swapped out motor in my old hatch like 10 times....it was a 97 and i always used the same harness....96-98 ex harness is what u need to make things easier and cleaner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghatch4sale »</TD></TR><TR><TD CLASS="quote">i love when people talk like they know what there talking about ............AND THEY DONT </TD></TR></TABLE>
We already know you don't. There was no need to point it out... again
IT'S ME DAVID
Feb 11, 2008 06:32 PM
HATCHingMN
14
Apr 3, 2007 04:19 PM
