URGENT: Cleaned re-re IAC now it wont start
Old Jun 13, 2006 | 04:14 PM
OrangeBoost's Avatar
Default URGENT: Cleaned re-re IAC now it wont start
So I just took off my IACV because my idle has been acting funny. I had cleaned it a week or two ago but I figured maybe it was leaking so Id throw a little rtv on the gasket surface. So I replaced it, plugged it in and now the car wont start!
No codes or anything, and sometimes it gives a little burp and tries to start but doesnt. Even feathering the gas doesnt do anything. It was running fine until the idle started moving around a little this morning and I need it to get to work in the morning! Help!
Old Jun 13, 2006 | 04:35 PM
igo4bmx's Avatar
gasket on the surface....
it didn't clog it did it?
Old Jun 13, 2006 | 05:45 PM
Syndacate's Avatar
either it clogged something or it's leaking, I've experienced this problem with the IACV too many times, I don't even take it off anymore, need to make sure both sides are thoroughly cleaned and scraped b4 applying the new gasket, and that liquid gasket **** don't work half the time so use a real gasket :-\
I hate that crap, it's happend to me like 3x
EDIT:My orig post may be way off, I just re-read ur post and I read it wrong...
It's possible that junk got in there and solidified, try taking it off and cleaning it thoroughly again, I highly recommend having a new OEM gasket though :-\
Old Jun 13, 2006 | 06:04 PM
Well it started without changing anything but it was surgin. Disconnected it and it idled perfect.
Now I go to start it again and it wont. Crap...its getting late and Im no further ahead.
Old Jun 14, 2006 | 06:19 AM
Well I got it running. It seems though that I can get it back to a normal idle by screwing the idle screw in tighter. This works at least temporarily.
motoguy126
Aug 14, 2017 03:22 PM
ericstambaugh07
Mar 13, 2007 05:10 PM
pimpami333
Feb 13, 2007 10:30 AM
skater5067
Apr 22, 2005 08:24 AM
