OEM Clutch
Old Jun 13, 2006 | 04:07 PM
MuthaFodder's Avatar
Default OEM Clutch
Does anyone know who makes the original (OEM) clutch, either currently or past.
I have heard that the clutch is universal for all 4cyl. models from 1990-2002 as well.
Comments please....
Old Jun 13, 2006 | 04:09 PM
Ross 2.0's Avatar
In a Junkyard near you.
The clutch for your 99 Accord? Honda makes it.
http://www.magauto.com
Old Jun 13, 2006 | 04:14 PM
Default Re: (MooGoCow3)
I mean no disrespect, but Honda makes their own clutches?
Old Jun 13, 2006 | 04:19 PM
Ross 2.0's Avatar
yes they do.
Even if a sublet company made the clutch that companies brand clutch for the same car would not be the same (copyright)
Old Jun 13, 2006 | 04:21 PM
OK then, so if Exeddy actually made the clutch...we wouldn't really know becasue Honda puts their name on it?
Old Jun 13, 2006 | 04:25 PM
I couldn't call local so I called California Parts Department:
"Honda does not make the clutches, nor are we told who makes them. Our suppliers make them to Honda specs, Honda is just a company that puts pieces together to form a car."
This is what I figured, but there must be a way to find out who supplies these 'Spec' clutches to Honda...after all there surely wouldn't want to keep that a secret.
Old Jun 13, 2006 | 04:29 PM
Ross 2.0's Avatar
http://www.hondaautomotivepart...ERTER
Old Jun 13, 2006 | 04:31 PM
Default Re: (MuthaFodder)
From researching thus far:
"Exedy is the largest supplier in Japan to Japanese automakers."
http://exedyusa.com/profile/index.shtml
The EXEDY Group supplies Manual Clutches, Flywheels, Torque Converters, AT Plates or other advanced Powertrain Components to all 11 vehicle manufacturers in Japan as well as many other vehicle manufacturers, construction / machinery industries in the world including GM and Ford. EXEDY Globalparts (USA) now distributes all EXEDY, Daikin and Dynax (AT related) products to the aftermarket for all of North, Central and South America.
The full range of products available through Exedy Globalparts Corporation includes:
A full range of clutch kits to suit Japanese, US domestic and European applications.
Sports clutch kits with organic, cerametallic and carbon friction material in single, twin, and triple plate configurations featuring chromemoly flywheels.
Dynax branded OEM quality friction plates and steels.
Clutch forks
Clutch thrust release bearings
Clutch cables
Clutch master and slave cylinders
OEM standard replacement flywheels
Heavy duty class 7 & 8 clutch sets
Old Jun 13, 2006 | 04:37 PM
Yeah I found that, but I see no reason to buy inflated products just because Honda sells it....I'd be paying for the middle man.
Honda Service Department already stated they would install parts off the street, which is still outrageous at over $400 in labor.
I have put transmissions, clutches, etc. in my own Hondas in the past. But, sometimes the opportunity cost of having someone else do it is better....but not at $400.
I beleive I will have my mechanic do it instead (Retired Infiniti Master Mechanic), after all its just a clutch...not an engine transplant.
...Now back to the topic at hand:
I have been told that Honda does not make their own clutches just a few minutes ago by the Parts Manager. So, who can confirm supplies clutches?
Old Jun 13, 2006 | 04:49 PM
Ross 2.0's Avatar
You arent going to do any harm by installing an aftermarket clutch. Just as long as it's not a cheap or no name clutch.
But that parts manager is kinda incorrect. He made it sound like when he orders a clutch through honda it shows up in an aftermarket box. This is not the case. It very well may be an aftermarket company that makes the clutch (as well as many other honda parts). But he has no way of telling that this is the case.
Old Jun 13, 2006 | 04:55 PM
Right, its in a Honda box, guaranteed, hoo-hah.
But, we all know its not Honda in that box...more of an approved provider.
Thanks, based on my reasearch, Daiken has been engulfed by Exedy and both supply the majority of OEM parts to manufacturers. Their replacements aren't OEM becasue they aren't supplied directly by Honda. Even though the clutch's only difference is the box.
Its like Pirelli is the OEM for many new BMWs, Infinitis, etc. But the dealers aren't the only place to get those tires, hence an OE replacement by the direct manufacturer.
Old Jun 13, 2006 | 04:59 PM
Ross 2.0's Avatar
Well you missed my point but ok.
The clutch isn't exactally the same (it's close if not better). But no need to nitpick it.
I could get into hondas tires too but i'm not going there in this thread. lol
good luck on getting it replaced!
Old Jun 13, 2006 | 05:07 PM
I understand you are a Honda Technician and you will be forever biased for that...but that isn't necessarily a bad thing for you...knowledge is great.
But, I was at my Honda dealership today and asked where the Volvo dealership was, mind you a very small city, and low-and-behold....no one knew.
Its great to stick by your guns, but what I came on to find out through discussion was who gives Honda the clutches that you put in your Honda box.
Just because it has Honda's name and its in their box, doesn't necessarily mean they made it...but they sure can put together a hell of a car with the best pieces!!
Old Jun 13, 2006 | 05:09 PM
Ross 2.0's Avatar
good luck
Old Jun 13, 2006 | 05:10 PM
BTW, I seriously doubt Honda has a patent on the 'Specs' that a supplier made for them...that just screams lawsuit.
Again, I doubt the supplier would let Honda limit them reproducing and selling a product with the same 'Specs', but they could prevent them from marketing them as Honda parts.
Old Jun 13, 2006 | 06:06 PM
momstaxi's Avatar
diaken (exedy) makes them
stamped on the clutch disc and pressure plate
i replaced one with an exedy "oem replacement" that i got for $99, exedy box, same stampings and #'s as orginal clutch pulled from motor on both clutches.
Old Jun 13, 2006 | 06:12 PM
Default Re: (momstaxi)
AMEN.....THANK YOU!!!
I bet you could get a set of aftermarket tires identical to the original ones and by the same manufacturer too...Hoo-Ra
xo1996hondaxo
Jun 10, 2012 04:26 AM
nnamssorxela
Transmission & Drivetrain
Feb 13, 2011 10:15 AM
TypeR324
Honda S2000
Oct 8, 2008 09:52 AM
43!
Oct 22, 2006 08:05 AM
