cant get fuel filter line off, need help
Old Jun 13, 2006 | 03:56 PM
clemsonteg's Avatar
Default cant get fuel filter line off, need help
I was trying to change my fuel filter today and I couldnt get the bottom fuel line off, is there some kind of trick to get it off? i couldnt figure out how to get it off, advice would be appreciated
Old Jun 13, 2006 | 05:39 PM
project_delta's Avatar
It's probably just a little seized on from not being taken off for a very long time. That's the one that has a flare fitting on it, right? Use a flare nut wrench, otherwise you might round off the edges of it, then you'll really be stuck. Try spraying some penetrating fluid on it first. If that still doesn't work, you could try using vice grips, but you'll probably damage the fitting if your not careful. Good luck.
Old Jun 13, 2006 | 05:41 PM
MR_Ek4's Avatar
Default Re: cant get fuel filter line off, need help (clemsonteg)
If im correct there is a nut on top that you have too have a wrench on and also the one on the bottom it might be vice versa but if you just using one wrench and not sercuring the other bolt it wont come off at all.
Old Jun 13, 2006 | 06:09 PM
addiction2bass's Avatar
Default Re: cant get fuel filter line off, need help (EM1_00MRBuilt)
just changed mine last week..... DEFINATLY put a wrench on the filters top bolt, and use a line wrench on the bottom.
for mine it helped ALOT to remove the air duct work from off the intake and filter box.
it still took me quite a bit of work to break that sucker loose!
MelJ
10
Mar 20, 2011 05:26 PM
LyghtFunky1
14
Jun 13, 2008 03:09 PM
csambitions
Jun 28, 2004 08:39 AM
get wet racing
Jan 6, 2003 06:16 AM
AK94GSR
Aug 7, 2002 08:02 PM
