Help convert 97 accord to 5 lug wheels
Old Jun 13, 2006 | 03:49 PM
danielhall's Avatar
Default Help convert 97 accord to 5 lug wheels
I bought a 97 accord wagon which the guy had converted to 5 lug and put on some very nice 17 in acura wheels. Car looked great till i changed the tires and realized that he butchered the back end. The front wheels are fine.
He couldnt find a 5 lug hub that fit the abs in the rear so he drilled right into the stock hubs leaving two of the 5 lugs hanging on and almost worthless. So im running on 3 of 5 lugs and need to get it fixed.
Has anyone else converted an accord to 5 lug. Do you know of a 5 lug hub that will fit a 97 accord for the rear wheels.
I have talked to the previous owner but havent got much valuable info from him. Win some and lose some i guess. Please help if you can.
Dan
Old Jun 13, 2006 | 03:53 PM
Ross 2.0's Avatar
In a Junkyard near you.
"Your search for lug conversion returned 35 results."
Click the read search button and give it a shot. There are plenty of threads out there
Welcome to H-T
Old Jun 13, 2006 | 05:34 PM
AccidentproWn's Avatar
Default Re: Help convert 97 accord to 5 lug wheels (danielhall)
go check out http://www.accordinglydone.com. I saw an article on there a while back for converting a 4 lug to 5 lug accord. I seem to recall him using Odyssey hubs.
Old Jun 13, 2006 | 06:18 PM
YeuEmMaiMai's Avatar
if you have 15" rims or larger, why not convert the car to V6 brakes at the same time? The 5 lug conversion will be a benifit of that.
just use the rear spindles from the V6 car if that is all you want to do is the back wheels
Old Jun 13, 2006 | 08:09 PM
honda_kid42's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">if you have 15" rims or larger, why not convert the car to V6 brakes at the same time? The 5 lug conversion will be a benifit of that.
just use the rear spindles from the V6 car if that is all you want to do is the back wheels</TD></TR></TABLE>
this is very true....i did some reading on it awhile back...
Old Jun 13, 2006 | 10:50 PM
talontsiawd's Avatar
Although true, you have to buy new wheels so it doesn't matter what size wheel you have to begin with.
g2tegsownsgirl
May 3, 2006 06:40 AM
Klutch
May 4, 2005 06:01 PM
mk3veedubjetta
Feb 14, 2005 05:07 PM
skoolnu
Dec 1, 2002 07:13 PM
ddd75
Aug 10, 2002 02:31 PM
