New Titanium Coatings! PICS
Just received my turbo components back from the shop today. Its coated with a titanium coating that can with stand up to 1800 degrees! or so they say...Dont know if many people have experienced with it, but if you do chime in! This stuff better not melt off haha!
Im going to be using the blox manifold, gonna see if i can make 500-600 hp off it. So we'll see how it will perform. Hopefully it will hold!
Pictuers...
BEFORE
AFTER
Here is a picture of the intercooler piping made by Spoolin that will be used with this setup!
Hope to get this going either this weekend or next....ill post results on how the coatings hold up later...
Just curious....how many people actually coat their manifolds and what not and how well did it hold up?? thanks!
Pictuers...
BEFORE
AFTER
Everything looks great. Will see if the coating holds up
My coating has been great thus far. My exhaust manifold, turbine housing and wastegate are coated. Downpipe and dump tube are thermal wrapped
It's temperature rating is at 1800 degrees as compared to the flashy shinny ceramic coatings which is only rated around 1200-1300 i beleive and the jet black coating is rated around 1500-1600....
correct...its the ability of the coating to withstand heat and retain heat inside the components best it can without peeling...or flaking off... it does more then show it trys to retain heat! and it keeps ur crap from rusting!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">"Show off coating" - what the hell? Chrome is a show off coating, thermal coating is good stuff.
That thin crap is to keep you from seeing rust.
Get Swain then you'll see a difference.
</TD></TR></TABLE>That thin crap is to keep you from seeing rust.
Good coatings doesnt necessarily have to be "Caked" on there for it to work...reason why its thermal coating. Dont really know how many coats or the process they go thru for doing it, but i know they sand blasted it all down to bare metal, then coat it!
But hey, just as long as it works im happy!
You should vent your engine bay with a marine engine fan get heat out better, I know you just got the coating and all but thats not gonna touch anything swain coated...I'll call that cosmetic because that stuff is thin.
any pics of the swain stuff your talking about...whats it rated at? I have seen that white coating, forgot who does it here...and the blue smurf coatings, im not sure what they are rated at either...but those look good to...
Guest
Posts: n/a
how much is swain to coat a ramhorn though? Looks like it could cost up to 300 bucks just for the manifold, then 150 for a the dp. Thats a tad ridiculous for a coating. Especially for him, where the manifold itself only costs 300. And im sure his coating will reduce heat quite a bit, just may not be as good as swain.
Yeh...only paid $210 for everything...My freind got his jet coated black at HPC and his is started to flake on his ramhorn...But he also detonated his motor twice!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">Swain told me $250 for the manifold (lovefab sst). It is put on very thick (for ceramic coatings at least).
Did they do the inside and outside of everything?</TD></TR></TABLE>
Read my link posted above, they tell you what coatings are preferable and at what thickness they are put on
have you tried fitting the center section of the turbo back on the exhaust housing yet??
just curious about how thick that coating it or whatnot??
wondering if it affects the clearance any??
oh yeah and how do the bolts thread now??
Nice coating I did my turbo hot housing and downpipe black coating held up for 2 years cost me 12.75 one can from pep boys works prety good then I got crazy and did the complete exhaust on a buel and still looks good you guys should look into that paint is exhaust paint it holds up 1400 to 1800 I dont think honda exhaust gets that hot I know rotary get very hot and read even that was about 1200.
