Help after B20 swap, PLEASE im stuck
Old Jun 13, 2006 | 03:20 PM
secluded luder's Avatar
Default Help after B20 swap, PLEASE im stuck
I just finished my swap and went to fire up my lude its a b20 swapped 1991 prelude 4ws.... it instantly ( right from start up) goes to redline. has anyone encountered this? i have changed ecu's, the vac control box, and tried to check all the vac line, what could it be?
also i just discovered the clock fuse is popping when i advance the key........
Modified by secluded luder at 5:39 PM 6/13/2006
Old Jun 13, 2006 | 03:48 PM
darkspector's Avatar
is your throttle installed right?
Old Jun 13, 2006 | 04:00 PM
Default Re: (darkspector)
i have had no luck with this project at all,im tearing it all back down
Modified by secluded luder at 8:20 AM 6/14/2006
Old Jun 14, 2006 | 04:48 PM
car starts and revs continuosly from 1-5k
Old Jun 14, 2006 | 04:59 PM
98vtec's Avatar
moderator emeritus
Default Re: (secluded luder)
sounds like you have a very large vacuum leak.
what all did you do?
Old Jun 15, 2006 | 08:11 AM
i swapped out my blown b21 for a jdm b20 hooked everything back up and this is what i get
Old Jun 15, 2006 | 11:30 AM
shanman2112's Avatar
try a leak in ur intake manifold gasket- i had the same problem when i swapped in my h22
TeamRPM_ZC
Apr 27, 2008 12:17 PM
antaren
Oct 20, 2007 11:17 AM
Nipsey Hussle
Aug 6, 2005 07:18 AM
