Air Mass Sensor?
Old Jun 13, 2006 | 02:17 PM
PogiDC5's Avatar
Default Air Mass Sensor?
While i was swaping my AEM intake to my V2 intake for my DC5 and i forgot to unplug my (-) terminal from my battery and no key was in the ignition. i swaped it out and when i turn on my car the CEL light turned on... so i figured it was beacuse i unpluged my Air mass sensor... so i hit up my Fuse box and reset my ECU... but now my gas mileage is like 245miles on a Full tank... before i use ta get like 275-280ish.... n e idea's ?? busted Airmass sensor ????
Old Jun 13, 2006 | 09:41 PM
diewX3's Avatar
Are you talking about the intake air temp sensor? Is the CEL still popping up? Are you sure you aren't flooring it more than usual?
Old Jun 15, 2006 | 02:09 PM
k20tuner's Avatar
Default Re: Air Mass Sensor? (PogiDC5)
If you had an AEM Cold air on I'm wondering why you would put on a V2 of all things? But it could be the filter, they can make or break gas mileage. Get a K&N with an inveted cone on it and the mileage should go back up. If not put the AEM back on with the K&N filter. How long did you leave the fuse out to reset the ECU? Should have been left out for about 30 minutes. I have on an AEM ca with the K&N and I can get over 350 miles per tank easy.
phandovan
Feb 20, 2007 06:09 PM
j0nptw
Feb 19, 2006 12:54 PM
luckyzz
Apr 28, 2004 07:13 AM
civicdragger818
Oct 24, 2002 07:10 AM
