100 oct pump gas K24... how much comp?
So i found a place locally that sells 100 octane at the pump...
I'm thinking ahead to my bottom end build and I'm wondering what kind of compression I can run on 100 oct and nothing less.
I'm also thinking about running a little nitrous maybe 100 shot
could I get away with 13:1?
87x99 K24 IPS KME's tuned with AEM EMS
ah Jon you know the answer to that question. Its all in the piston/chamber design and the aid of thermal barrier coatings. Although i think i would stick with the 12:5:1+some flat faced valves to get you in the 12:8 range and still have full VTC advancement if you desired
13:1 on 92?
I was told that 12.5:1 would be pushing it on the other crappy 91 cali premium...
maybe I'll settle for 13:1 with the 100oct
The KME's are not the K2-SE stroker cams. The KME's are pretty much a race oriented cam that will benefit from head work, more compression, and a bottom end with some displacement and ability to hold together at more than OEM redline...
The stroker cams are a version of his K2 street cams, that can be used in a stock 2.4L motor, and give better resluts than the original K2's since the new "stroker" version was made with a bigger displacement motor in mind. I think they were made with a stockish redline in mind, but they will perform in a mild/wild build but IPS may have something better for that...
I chose the KME's because the car will be mostly Road Race dedicated and I'll be building a block after I see what the stock block can handle with a mildly built head...
for more info on the K2-SE cams see this thread...
http://www.k20a.org/forum/showthread.php?t=13891
KME's
http://www.k20a.org/forum/show...t=KME
KME's
boostedblack99
Jul 27, 2004 08:18 PM
