Warm Start - Car Bogs n Shuts Off (TE ng55, gm 3 bar) WHY?
Old Jun 13, 2006 | 02:39 AM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Warm Start - Car Bogs n Shuts Off (TE ng55, gm 3 bar) WHY?
Been having this problem for a while now but its pretty dam ******* weird
You can go for a 30 mile drive, car running perfect the whole time and say you turn the car off and then start it withing 5 seconds itll continue to run perfect and startup and idle just where it was 5 seconds ago (750)
But if you shut the car off and come back 5min-30min later, maybe even longer, itll startup, run for about 2 seconds then go fairly lean (18:1) and then the rpms just drop low and the car dies.
You can fight it by pressing the throttle but the car soudns like **** and it runs lean.
You can also just start driving the car (which I hate doing cause its not warmed up) and once youre driving for 15 seconds or so, itll run just ******* fine with no problems until you turn it off again.
I tried richening up the idle and I like the car how its sits @ 14:1 right now and it still does it
The car is a crx, turboedit, 450's, gm 3 bar running ng55 code I believe
Need some help
Thanks
Old Jun 13, 2006 | 12:00 PM
PINKS's Avatar
Default Re: Warm Start - Car Bogs n Shuts Off (TE ng55, gm 3 bar) WHY? (PINKS)
Old Jun 16, 2006 | 01:38 AM
PINKS's Avatar
Its running LEAN on the warm start
18:1+
Would a main relay possibly cause that?
Old Jun 16, 2006 | 12:22 PM
PINKS's Avatar
When its cold out and cold start I will idle at 1500 til it warms up, when its warm out and im driving itll idle @ 700
But when its hot out and I come back out 30 min later and try and start it it just wants to die and cut out and I have to peddle it to keep it alive.
Where would I make the adjustment?
I dont hear the relay clicking but im running open 3" downpipe
The cel does nto come on though
Old Jun 21, 2006 | 06:14 PM
PINKS's Avatar
I cant seem to do anything, you knows more about turboedit and can help me
My car idles really low like 600 and when I try and richen it up at idle I cannot restart the car and keep it running, it just leans out. The only way I can get it so it will start up when warm and actually keeep running (even though it runs like ****) is to have my car idle at about 13.8-14:1 AFR
If I lean it out any more the thing just leans right out and cuts off and the idle seems to drop even more
Need help
Old Jun 22, 2006 | 02:27 AM
PINKS's Avatar
Someone told me it was just turboedit not readjusting for the heatsoak in the motor
Or is it a main relay problem here?
Old Jun 23, 2006 | 02:31 AM
PINKS's Avatar
jscblulu
Jan 12, 2007 03:24 PM
PINKS
Jun 23, 2006 02:55 PM
PINKS
21
Jun 23, 2006 12:02 PM
kaj
Feb 20, 2006 04:38 PM
