WTB: 96-98 SOHC swap + Power Steering system
Im looking for a 96 - 98 SOHC swap...CX,DX,EX...doesnt matter, but EX would be the nicest.
I need the motor, tranny, axles, linkage, mounts, ecu.
EDIT: Dont need the power steering stuff anymore...still need a swap though.
[Modified by HX_Guy, 2:09 PM 4/18/2002]
I have the power steering pump/pulley/bracket etc from a 98 civic ex. I put it into my crx and couldnt use the power steering. email me if interested....
Steven
Steven
Also, a complete powersteering system with the hoses and all.
Anyways, Free BUMP
I heard about you selling your motor... So how much is that going for?
Basically it will be:
2000 CRV B20Z2 block
1999 SI B16A2 head
Endyn 84.5mm pistons (11.94:1 CR)
Eagle rods
GSR crank girdle/windage tray/oil pickup/oil pan
New bearings and seals*
New oil pump*
New timing belt*
1997 Spec ITR cams
Portflow retainers
Portflow inner valve springs
ITR outer valve springs
Skunk2 cam gears
ITR intake manifold
JG 64mm Throttle body
Ported JDM ITR 4-1 header
B&M fuel pressure regulator
Walbro 255 LPH fuel pump
Stock 240cc injectors
Chipped P28 ECU w/Mugen chip
VAFC (tuned for setup)
96-98 OBDII - OBDI ecu harness
GSR transmission
Clutchmasters 7.5 LB flywheel
ACT Street/Strip clutch
Axles, mounts, shift linkage
The engine dyno'd at 208 WHP / 154 TQ and ran 12.91 @ 106.98 MPH on drag radials in a 2450 w/driver Civic.
EDIT: The engine has 4,000 miles on it
[Modified by HX_Guy, 11:04 AM 4/18/2002]
I have a PS pump from my 98 EX, I don't use PS anymore if you'd like it...
...still need a swap tho.
I have a 97 cx motor and everything you need for the swap. It has 70,000 miles on it and runs good, uses no oil!
Let me know if interested.....
BTW: I am interested in buying the B20/VTEC setup, please let me know something thanks....
[Modified by b18cef, 12:07 AM 4/30/2002]
[Modified by b18cef, 12:47 AM 4/30/2002]
