CV axles bent..
Old Jun 12, 2006 | 06:36 PM
Turbo_honda's Avatar
Default CV axles bent..
I have an H22a in my 97 civic coupe.. The hasport axles I have on the car dont fit in right.. They arent bent parsay, but they are bent back in an angle.. Do any of you have any ideas of new axles so they sit in there straight.. I have been told that there is no axles that will fit.. but will anyone help me with this.. thanks..
Old Jun 12, 2006 | 09:48 PM
can nobody help me?
Old Jun 12, 2006 | 09:50 PM
FalkenSiR's Avatar
Default Re: CV axles bent.. (Turbo_honda)
Are those axles supposed to fit your h22 in your car?
Old Jun 12, 2006 | 10:26 PM
They were the ones that I got with my complete swap.. But they don't seem to fit right. I want to get some that will fit in there straight so I have less of a chance of braking them..
Old Jun 13, 2006 | 01:46 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_honda &raquo;</TD></TR><TR><TD CLASS="quote">The hasport axles I have on the car dont fit in right.. They arent bent parsay, but they are bent back in an angle.. Do any of you have any ideas of new axles so they sit in there straight.. </TD></TR></TABLE>
do you have pics? pics will go a long way as i have no idea what you are referring to.
Rodney's Avatar
do you pics? pics will go a long way as i/we have no idea what you are referring to.
Old Jun 13, 2006 | 08:51 AM
Yeah I can take some pics and but them on here..
[IMG][/IMG]
Modified by Turbo_honda at 10:28 AM 6/13/2006
Modified by Turbo_honda at 10:29 AM 6/13/2006
Old Jun 13, 2006 | 04:06 PM
DelSolMarine's Avatar
Default Re: (Turbo_honda)
whered u get the swap from?
Old Jun 13, 2006 | 05:08 PM
CivicVX94's Avatar
ya i'm a b series guy so idk much about the H's BUT from what i've read you need custom axles for H series swaps into civics.......so if you're using the stock H series axles that could explain your problem.
if that's not it then i'll throw this out here. the mounts that you need to put an H in a civic cause the axles to be a slight angle (maybe this is your problem) and tons of people have problems with them breaking.
i hope this helps but ya so give us some more info on your setup (axles, mounts, etc)
Old Jun 13, 2006 | 07:13 PM
Its a 95 H22a, I have hasport mounts and hasport high horsepower axles.. I got the whole setup from Hmotorsonline...
Old Jun 13, 2006 | 08:30 PM
Luserkid's Avatar
They look good to me. Unless your super slammed where your hubs are the same angle as your tranny you wont get a completely straight axle.
Old Jun 13, 2006 | 08:47 PM
TwoKSiR's Avatar
Raise the car back up, slammed = blocken axles.
Old Jun 13, 2006 | 10:16 PM
I think I might have broken one of the axles tonight.. Hitting a curb= the suxors... But on a serious note is there any way of fixing the bent axles..
Old Jun 13, 2006 | 10:17 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
You drove into a curb??
Old Jun 13, 2006 | 10:18 PM
I think I actully broke the axle.. passenger side... Hitting a curb= the suxor... but on a real note, how do I fix the bent axle problem..
Twoksir- what are you talking about slammed = blocken axles..
Old Jun 14, 2006 | 05:02 AM
cockerkid008's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_honda &raquo;</TD></TR><TR><TD CLASS="quote">I think I might have broken one of the axles tonight.. Hitting a curb= the suxors... But on a serious note is there any way of fixing the bent axles..</TD></TR></TABLE>
drifting
Old Jun 14, 2006 | 07:07 AM
not on purpose... another car and wet surfuce.. hydroplaned into a curb...
the axle didnt feel broke, but the tire is way off alignment..
Old Jun 14, 2006 | 07:10 AM
tatmark1's Avatar
just like luserkid said that axle looks fine.
Old Jun 14, 2006 | 07:12 AM
so what your saying is it isnt bent? because when your under the car looking at it, the axle looks bent, from where it is there, then straightens out..
Old Jun 14, 2006 | 07:15 AM
tatmark1's Avatar
they dont sit completely straight.from your picture it looks fines,shaft doesnt look bent
that your driverside?
Old Jun 14, 2006 | 07:25 AM
no passenger, best side i could get the picture on.. without laying under the car..
Old Jun 21, 2006 | 02:47 PM
TwoKSiR's Avatar
When you lower the car it puts axles at the angle, and also weakens them and makes tham break alot easier. If you want to straighten axle back out raise your car up a little bit.
Old Jun 21, 2006 | 02:56 PM
NY93CivicEx's Avatar
Default Re: (TwoKSiR)
i have a 93 H22a Turbo swapped 93 civic coupe. You need the Hasport mounts and Hasport Axles (my car is dropped 2.2 all the way around w/ Eibach springs. When i bought my complete swap from Hmotors i got the 90-93 teg axles. They worked alright (except around high speed turns/sharp turns they would bind) This year when i had my custom turbo setup installed.. we took 'em out, and when we went to dyno the car they wouldnt go back in.. i dont know if it was the extra weight leaning over the front end or what but i couldnt drive over 10mph without the entire car shaking. The 90-93 teg axles were too long.. and my car was too low. I bought new springs, 1.25drop.. did some weight reduction (system gone, backseat/bealts/panels/moved battery to the trunk.. etc) and ordered Stage 1 Axles from Hasport. With both axles frmo hasport in the car, the problem continued. I got a tip off of a friend to use ONE Hasport axle on the drivers side... and then use an Accord Intermediate Shaft - with one 90-93 teg axles on the drivers side (because the prelude intermediate shaft is male-female it wouldnt work with both teg axles apparently?) So basically.. dont ask how or why, but my car runs perfect with 1 hasport axles on the drivers side, and an accord intermediate shaft with one 90-93 ls teg axle on the passenger side.. good luck
Old Jun 21, 2006 | 02:57 PM
Slamaccord's Avatar
If you have a bent axle you would be experiancing a wicked vibration and
probally would have broke by now.
So finally what is the solution for all you h22 powered Civic gurus.
I've been asked this question numerous of times and really don't know the true
answer. I usually tell them to use the hasport mount kit with hasport axles.
I hope I'm not giving bad advise.
Old Jun 21, 2006 | 06:28 PM
Brick Top's Avatar
thats how the axles sit in all h22 civics. they lean back because the motor leans back and throws the axle alignment away from the hub. the passenger axle never seems to hold up. my buddys hasport CV joint fell apart on him after 12 months. my solution? H2B tranny conversion kit. the b-series tranny seems to keep the axles at a straight angle.
Eduardo_95
Jul 16, 2015 03:11 PM
luis31
Oct 6, 2008 05:16 PM
blake22
Feb 18, 2007 06:59 AM
myhatchblubyu
Oct 25, 2001 03:03 PM
