1996 spec ITR wheel bearings same as USDM GSR?
Old Jun 12, 2006 | 06:19 PM
NIKE SB'd's Avatar
Default 1996 spec ITR wheel bearings same as USDM GSR?
I'm pretty sure it's the same bearing but I just wanted to verify
Old Jun 12, 2006 | 08:41 PM
DB8ITR's Avatar
Default Re: 1996 spec ITR wheel bearings same as USDM GSR? (NIKE SB'd)
Yep. Here are the two different part numbers that you can use either of.
44300-S04-A02
44300-S5A-004
There are two different manufacturers of seals, hence the two part numbers. I just swapped my 96 spec to 5 lug about two months ago and I used 44300-S5A-004.
Old Jun 12, 2006 | 11:46 PM
NIKE SB'd's Avatar
awesome thanks man
SOHCunderdog
Nov 9, 2010 07:19 AM
TerribleToo
Mar 5, 2010 01:08 PM
DBada FM
Oct 7, 2009 11:45 AM
NoLeftTurn
Sep 9, 2009 05:11 PM
Willard
Apr 2, 2002 06:11 PM
