Vacum Line?
Old Jun 12, 2006 | 02:26 PM
baPES's Avatar
Default Vacum Line?
I want to know if anything connects to that. I dont see any lose vacum lines orr anything Let me Know
Its a d16z6
Modified by baPES at 3:52 PM 6/12/2006
Old Jun 12, 2006 | 02:42 PM
Archidictus's Avatar
Unceasing Measure
Can you make that picture smaller and not on crack?
Old Jun 12, 2006 | 02:46 PM
freezerburnv2's Avatar
Default Re: (Archidictus)
yeah take another picture futher out and make it a bit smaller, I'll check my engine and tell ya what I think it connects to.
Old Jun 12, 2006 | 02:47 PM
baPES's Avatar
Ok
Old Jun 12, 2006 | 02:48 PM
sohcvtec1995's Avatar
it looks like its under the fuel line, by the TB something under tehre. i can kinda see a nipple coming out of there.
Old Jun 12, 2006 | 02:49 PM
ironcheftony's Avatar
that looks like the nipple for a coolant line going to the Fas Idle Thermal Valve from the back of the head near the 4th cylinder by the intake manifold
Old Jun 12, 2006 | 02:51 PM
baPES's Avatar
Default Re: Vacum Line? (baPES)
Fixed image
Old Jun 12, 2006 | 02:53 PM
baPES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">it looks like its under the fuel line, by the TB something under tehre. i can kinda see a nipple coming out of there. </TD></TR></TABLE>
Yea ur right its a nipple...It has a colant bypass system would that be the reason thats not connected. I didnt install it i got it like that
Old Jun 12, 2006 | 03:44 PM
baPES's Avatar
ne one? Would this mes sup my idle
Old Jun 12, 2006 | 04:50 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baPES &raquo;</TD></TR><TR><TD CLASS="quote">ne one? Would this mes sup my idle</TD></TR></TABLE>
Define for us what your idle is doing and we can tell you, nooblet.
Old Jun 12, 2006 | 06:03 PM
allmotorsi04's Avatar
Default Re: Vacum Line? (Archidictus)
^^^^more info^^^surging or what?
Old Jun 12, 2006 | 06:11 PM
baPES's Avatar
Default Re: Vacum Line? (allmotorsi04)
it goes from like 1200-800
Old Jun 12, 2006 | 06:12 PM
baPES's Avatar
The main question was what exactly that is and if it needs to be connected or if thats not a problem
Old Jun 12, 2006 | 06:13 PM
does it fluctuate fast or slow?
Old Jun 12, 2006 | 06:15 PM
baPES's Avatar
It does it kind of slow but its noticable
Old Jun 12, 2006 | 07:09 PM
stock_honda_coupe's Avatar
Then there needs to be something there.
Old Jun 12, 2006 | 07:42 PM
its a coolant line, it cools the temp going into the intake mainfold. I would hook it up. and yes that could be the cause of your surgeing, since it is looking for it. ALso look foa vacume leak somewhere.
Old Jun 12, 2006 | 08:18 PM
baPES's Avatar
Default Re: (sohcvtec1995)
where would i hook it up to
Old Jun 14, 2006 | 06:53 AM
baPES's Avatar
Default Re: (baPES)
Up wheres that line go to?!
Old Jun 14, 2006 | 03:56 PM
Unceasing Measure
Default Re: (baPES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baPES &raquo;</TD></TR><TR><TD CLASS="quote">Up wheres that line go to?!</TD></TR></TABLE>
Goddamnit. That's your fast idle thermovalve and it's there to help idle under cold weather conditions. If you have nothing going to it, that's fine: but you need to block it off completely if you want your idle to stay normal because even a pinhole in the wax inside that bastard will result in fluctuation. Make a plate of slip a vacuum nipple on there and call it a motherfuckin day.
Old Jun 14, 2006 | 08:29 PM
baPES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Goddamnit. That's your fast idle thermovalve and it's there to help idle under cold weather conditions. If you have nothing going to it, that's fine: but you need to block it off completely if you want your idle to stay normal because even a pinhole in the wax inside that bastard will result in fluctuation. Make a plate of slip a vacuum nipple on there and call it a motherfuckin day.</TD></TR></TABLE>
Wow thast what Ht is here for help no need to get all mad
Old Jun 14, 2006 | 08:32 PM
thahuhstunna's Avatar
Default Re: (baPES)
just be more specific next time and all will be well... i just didn't know you loved vaCUUM lines so much
powerdbygarrett
Oct 19, 2007 09:35 PM
E.Honda
Jan 20, 2006 02:12 PM
sldcivic
Jan 18, 2006 09:14 AM
SpeedDreamz.com
May 30, 2004 02:07 PM
aaj23
Jul 17, 2003 10:11 AM
