What do you guys think of this DIY manifold?
Old Jun 12, 2006 | 02:21 PM
CBURKE's Avatar
Default What do you guys think of this DIY manifold?
I have never done one before but this looks pretty easy, I will be using a flux (I think it's called) weld. I'm new to welding and just trying to learn on my own.
http://tunertoys.zoovy.com/product/LMKBT3
Old Jun 12, 2006 | 03:53 PM
RCautoworks's Avatar
Default Re: What do you guys think of this DIY manifold? (CBURKE)
You could piece together the same kit for cheaper, why not do that ?
From the pictures, what they forget to tell you is you will still have to cut the T fittings down, so its not a really a weld up kit.
Old Jun 12, 2006 | 09:39 PM
CBURKE's Avatar
Do you know where I can get the pieces from?
Old Jun 12, 2006 | 09:59 PM
Default Re: (CBURKE)
http://www.mcmaster.com
http://www.bmcrace.com
Old Jun 14, 2006 | 06:51 AM
CBURKE's Avatar
thank you sr
Old Jun 15, 2006 | 06:47 AM
CBURKE's Avatar
TTT
Old Jun 15, 2006 | 07:13 AM
ManBearPig4silly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">TTT</TD></TR></TABLE>
You already have all the answers to the questions you asked. If you have another one fire away. Don't just bump for the sake of bumping please.
Old Jun 15, 2006 | 08:02 AM
CBURKE's Avatar
opps I didn't mean to, but sence I did, is flux ok to use when doing this?
Old Jun 15, 2006 | 08:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">opps I didn't mean to, but sence I did, is flux ok to use when doing this?</TD></TR></TABLE>
As long as you know how to get proper pentration, yes.
Old Jun 15, 2006 | 08:26 AM
CBURKE's Avatar
I guess that's just playing with the heat. Now is it the hotter I go the more wire I need to feed? I am trying to figure out how fast I need the wire to go.
Old Jun 15, 2006 | 09:43 AM
ludesrv's Avatar
Practice makes perfect.
Try practicing on other similar metal, until you find a good wire feed rate to get deep and strong metal penetration.
Old Jun 15, 2006 | 01:28 PM
CBURKE's Avatar
When you have good metal penetration, is that when the under side of the metal is getting hot and you can see it burning?
Old Jun 15, 2006 | 02:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">When you have good metal penetration, is that when the under side of the metal is getting hot and you can see it burning?</TD></TR></TABLE>
Yes, pretty much.
Old Jun 15, 2006 | 02:44 PM
CBURKE's Avatar
cool thanks I think I'm good now.
Old Jun 15, 2006 | 02:47 PM
Let me know personally if you need help putting together a kit, or cutting pieces.
Old Jun 15, 2006 | 08:33 PM
Bailhatch's Avatar
Default Re: (90blackcrx)
make sure you bevel the fitting where ever you anre joining them end to end. Make a nice V shaped groove to fill up with the weld, that way its easier to melt all the way through or close to it.
Old Jun 16, 2006 | 04:26 AM
CBURKE's Avatar
got it thanks for all the help.
And 90blackcrx: will do thanks.
hbyrd8701
May 18, 2008 08:00 PM
akandok
Dec 21, 2006 11:25 AM
SiR99
Jun 1, 2006 11:11 PM
92b16si
Welding / Fabrication
Mar 17, 2006 04:48 PM
darkirony
Aug 26, 2003 12:01 PM
