BC4's and CTR's in lsvtec....help.
Old Jun 12, 2006 | 11:08 AM
bambam's Avatar
Default BC4's and CTR's in lsvtec....help.
what's up guys...
Here's the question:
I have an lsvtec setup right now. It has P30's and BC3's. I want to swap out the P30's for CTR's and the BC3's for BC4's. I was wondering how the Piston to valve clearance will be. I will definitely clay once I get them, but if they are known not to fit together, there's no point in me buying them. My PR3 head is milled .002 as well. My instinct tells me it won't be a problem at all, but just want to see what you're opinion is on this. I think tom run's the BC4's with over 13:1 compression w/ an LS crank/rods/block right?
I searched, but after 30 mins of searching, I couldn't fine exactly what I was looking for.
Old Jun 12, 2006 | 04:15 PM
bambam's Avatar
Default Re: BC4's and CTR's in lsvtec....help. (bambam)
bump...i even tried searching for ctr's and skunk2 stg 2 cams (same lift as bc4's) but no luck...
Old Jun 12, 2006 | 05:02 PM
drift4jesus's Avatar
Should not be a problem, if they are the same as skunk stg 2's. I KNOW those work with ctr pistons.
Old Jun 12, 2006 | 05:42 PM
ekVtecPower's Avatar
Default Re: BC4's and CTR's in lsvtec....help. (drift4jesus)
keep the p30's.. CTR's are too much compression.
Old Jun 12, 2006 | 06:49 PM
bambam's Avatar
Default Re: BC4's and CTR's in lsvtec....help. (ekVtecPower)
I have complete engine management, and I am a tuner myself, so tuning is NOT an issue with compression for me. I also have a gas station that has 110 octane down the street from me...so that's not a problem.
HECDWS
Nov 19, 2004 11:10 AM
PreStaged12s
Aug 6, 2004 02:40 PM
sir91
Apr 6, 2004 09:48 PM
FAST94GSR
Sep 19, 2001 05:58 AM
