Is this safE?
Old Jun 12, 2006 | 09:46 AM
mikkey1's Avatar
Default Is this safE?
13.1 comp on 81oct?
Modified by mikkey1 at 8:06 AM 11/25/2006
Old Jun 12, 2006 | 10:00 AM
acydphryck's Avatar
Default Re: Is this safE? (mikkey1)
no matter what rods you use, replace the OEM ones with ARP rod bolts
Old Jun 12, 2006 | 10:40 AM
mikkey1's Avatar
i will be using arp bolts and head studs :D
i will be running a chipped ecu from mtber or kenji before i get it tuned im a bit worried about driving it around, but will i be ok ? or will i ahve too much comp?
will i be ok with piston to valve clearence
Old Jun 12, 2006 | 10:54 AM
acydphryck's Avatar
Default Re: (mikkey1)
might have to clay the motor when u put it together just to make sure you get good piston/valve clearance
Old Jun 12, 2006 | 11:20 AM
mikkey1's Avatar
what is meant by clay
Old Jun 12, 2006 | 03:00 PM
zCivic's Avatar
Clay to mesure the valve clearence. Make sure you dont slap a piston into a valve and skew everything up.
http://www.c-speedracing.com/h...y.php
Old Jun 12, 2006 | 03:22 PM
PinkMaggit's Avatar
Couple of things i would checkout first
Dont use ctr pistons.
I dont think itr rods fit, 87 vs 89 But im not sure ask around.
Compression Calculators are wrong on the ctrs. in a LS block and a b16 head its 12.8:1 in a GSR head its higher. Bad for the street.
Use P30 Pistons 11.5:1 flat dome and arent as heavy
use Ls rods if your staying NA.
Vtec water and oilpump and a GSR timing belt along with the ARP's and your golden.
Searh reliable LS/VTEC
Old Jun 12, 2006 | 08:00 PM
UncleD's Avatar
Default Re: Is this safE? (PinkMaggit)
Yeah what head are you using? I'd be willing to bet you're overcamming also.
Old Jun 13, 2006 | 12:10 AM
mikkey1's Avatar
i will be running TODA c's and a b16a head with p+p, gas flowed.
Old Jun 13, 2006 | 12:39 AM
UncleD's Avatar
Overcammed.
Old Jun 13, 2006 | 05:45 AM
raphael's Avatar
what about gsr pistons as compared to p30 pistons
Old Jun 13, 2006 | 10:19 AM
mikkey1's Avatar
the dude that is building the motor for me said they would be fine.
when you say over cammed are my Cams too agrssive? or oposite?
Old Jun 13, 2006 | 11:47 AM
UncleD's Avatar
Too aggressive
BIGef
Sep 28, 2014 12:49 PM
OceanStateTuning
18
Mar 27, 2007 12:01 AM
aakeobo
28
Jun 30, 2005 04:02 PM
integra_dude
May 18, 2005 01:36 PM
ls95hatch
15
Apr 10, 2004 06:58 PM
