NEED HELP WITH IDLE
Old Jun 12, 2006 | 07:50 AM
ge_itr's Avatar
Default NEED HELP WITH IDLE
just bought 98 itr recently.my idle is set to 1,200 rpm. i don't know if it's my battery or need of tunning. my car has aem adj. camgears and skunk 2 stage 3 camshaft. hondata s100. my idle some how drops back and forth between 500 to 1,200 range. when it reach the 400-600 rpm the batter sign on the cluther flashes. sometimes it stays at the 1000 -1200 range for half second or min. then then repeats drop. i don't think it's my battery but it could be? i also think it could be my alternator. when stepping on gas. light on cluster. headlights with brigthen up.
Old Jun 12, 2006 | 08:02 AM
RTW DC2R's Avatar
you just bought the car with it running like this???
sounds like more of a "tuning" issue than anything else. Assuming the idle is setup correctly in Hondata, check your pcv hose on the intake manifold for holes, check the voltage at the battery, may just need to adjust the throttle body. Im willing to bet the battery light is only coming on because the car is about to die when idle gets that low.
But if those are stage 3 cams, I would bet on just a tuning issue and suggest having a Hondata tuner check it out.
Old Jun 12, 2006 | 08:26 AM
ge_itr's Avatar
Default Re: (clip the apex)
oh. i do have a 65mm throttle body. how do you you adjust it.
ex_ricer
Mar 20, 2008 05:25 PM
ThaCivicAssassin
Nov 30, 2006 01:55 PM
simplsi
Nov 7, 2006 08:28 AM
simplsi
Oct 26, 2006 12:25 PM
integra90xsi
Apr 25, 2004 12:41 AM
