want to find 15' rims that are compatible to gen5 prelude.
Old Apr 16, 2002 | 02:55 AM
Sleeping's Avatar
Default want to find 15' rims that are compatible to gen5 prelude.
Can anyone tell me which brand's 15' rim is compatible to gen5 prelude? Also where can I get it with the best price?
Old Apr 16, 2002 | 06:22 AM
himiler's Avatar
New User
Default Re: want to find 15' rims that are compatible to gen5 prelude. (Sleeping)
check on http://www.tires.com
I was on there the other night and they had lots of 15" wheels that'll work.
Or, find 4 Integra Type-R wheels--light and very strong.
Old Apr 16, 2002 | 06:24 AM
tec-9-7's Avatar
Also depends on intended use - if you are trying to mount snow tires, I've heard 15" steelies from CRV will work nicely.
Paul
Old Apr 16, 2002 | 07:03 AM
Greyout's Avatar
Default Re: want to find 15' rims that are compatible to gen5 prelude. (tec-9-7)
http://www.machiii.com
Old Apr 16, 2002 | 11:46 AM
bb6h22a's Avatar
Default You can use..
..the following, if your intention is to use 15 inch OEM wheels.
CRV steelies
ITR wheels
CTR wheels
All have the 5*114.3 bolt pattern, and the required offset.
Old Apr 16, 2002 | 11:59 AM
illusion's Avatar
Default Re: You can use.. (bb6h22a)
will 15's clear the rotor/caliper?
Old Apr 16, 2002 | 12:07 PM
Greyout's Avatar
Default Re: You can use.. (illusion)
yes, the brakes are the same size as both the 4th gen brakes and the ITR brakes
[Modified by JDM LUDE, 9:07 PM 4/16/2002]
Old Apr 16, 2002 | 12:15 PM
Variance's Avatar
Default Re: You can use.. (JDM LUDE)
Kosei K1?
Old Apr 16, 2002 | 12:18 PM
laughinxxx's Avatar
New User
now this is an interesting statement because I had to use a 3mm spacer on my JDM ITR rims to clear the caliper. Are the JDM and USDM ITR calipers different?
Old Apr 16, 2002 | 12:31 PM
Sleeping's Avatar
Default Re: want to find 15' rims that are compatible to gen5 prelude. (himiler)
Type R rim is good for prelude too? what is the weight of a typeR rim? I think I will get a second hand type r rim. I have to save my money for tires(performance use) too..
Old Apr 16, 2002 | 03:54 PM
Greyout's Avatar
Default Re: You can use.. (laughin2.2)
hmmm good question. I was thinking only of the diameter for the rim clearance, not of the backspacing for the spokes to clear.
Old Apr 16, 2002 | 05:35 PM
DirtyLude's Avatar
Default Re: You can use.. (HachiSix)
I second HachiSix. Kosei K1 Racings. Cheap, light, 15"x7".
Old Apr 16, 2002 | 06:51 PM
ELUD THS's Avatar
New User
Default Re: You can use.. (DirtyLude)
I do believe that rota makes a 15 in rim as well.
Malakai
Apr 5, 2012 05:08 PM
H24Turbo
Mar 4, 2009 06:30 AM
Petah
Nov 25, 2003 07:11 PM
ScareyH22A
Jun 4, 2003 08:15 PM
mattt
Dec 10, 2002 10:10 PM
