Dyno Tuning - B17 heads and cams
Old Jun 12, 2006 | 05:44 AM
BryanPendleton's Avatar
Default Dyno Tuning - B17 heads and cams
I brought my B17 Civic back to Jason Herrera (aka St00pid) this weekend for a retune. Since the last time he tuned it I removed the restrictive cat, installed my Flow Stack, and exposed the cam gears for tuning. Motor is a 100% stock B17 shortblock, head has mild port, bowl and chamber work, Omni flatbottom valves, 0.020" shaved on head with OE 3-layer gasket, omni valvetrain and BC3+ bump sticks, oh and I cleaned up the IM runner some. Base line pull left me a bit discouraged, as it was choppy and making very little compared to previous year. Adjusting that cam timing is when this thing cam ALIVE. It’s a different car now. Wow!. We picked up 20whp in spots. Unfortunately the ignition pickup was not functioning properly, so the only good data is the power vs speed graphs. But look at the difference. Jason did tune the car with motor before we started making cam adjustments, but it didn't smooth out the power much and gains were minimial. It was the cam timing that woke this motor up. Just a couple graphs to chew on. Final cam timing with my STR Pro 570 gears, which by the way are super easy to read and dial in, were +2deg EX/+2deg IN. Started by advancing the exhaust, +1, +2, then +3, dialed back to +2. Dialed in -1 on intake, then reversed to +1, then +2. After tweaking the exhaust, gains were minmial, so I settle with the +2EX/+2IN.
Before and after from this weekends tuning
Comparison of 2005 Tune vs June 06 Tuning
Old Jun 12, 2006 | 06:04 AM
UncleD's Avatar
Default Re: Dyno Tuning - B17 heads and cams (BryanPendleton)
Wow man thats sweet! Super simple build with some pretty decent results, what header are you running?
Old Jun 12, 2006 | 06:06 AM
Default Re: Dyno Tuning - B17 heads and cams (clean rice)
Simple and reliable, that may goal. Running the B16 DC 421 1-piece.
Old Jun 12, 2006 | 06:17 AM
mar778c's Avatar
Community Builder
Community Influencer
Nice numbers, strong engine.
Are you using the BPI stack on this build?
Old Jun 12, 2006 | 06:49 AM
West Werks's Avatar
Default Re: Dyno Tuning - B17 heads and cams (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanPendleton &raquo;</TD></TR><TR><TD CLASS="quote">I brought my B17 Civic back to Jason Herrera (aka St00pid) this weekend for a retune. Since the last time he tuned it I removed the restrictive cat, installed my Flow Stack<U></U>, and exposed the cam gears for tuning. Motor is a 100% stock B17 shortblock, head has mild port, bowl and chamber work, Omni flatbottom valves, 0.020" shaved on head with OE 3-layer gasket, omni valvetrain and BC3+ bump sticks, oh and I cleaned up the IM runner some. Base line pull left me a bit discouraged, as it was choppy and making very little compared to previous year. Adjusting that cam timing is when this thing cam ALIVE. It’s a different car now. Wow!. We picked up 20whp in spots. Unfortunately the ignition pickup was not functioning properly, so the only good data is the power vs speed graphs. But look at the difference. Jason did tune the car with motor before we started making cam adjustments, but it didn't smooth out the power much and gains were minimial. It was the cam timing that woke this motor up. Just a couple graphs to chew on. Final cam timing with my STR Pro 570 gears, which by the way are super easy to read and dial in, were +2deg EX/+2deg IN. Started by advancing the exhaust, +1, +2, then +3, dialed back to +2. Dialed in -1 on intake, then reversed to +1, then +2. After tweaking the exhaust, gains were minmial, so I settle with the +2EX/+2IN.
Old Aug 17, 2006 | 02:32 PM
DAgsr's Avatar
Default Re: Dyno Tuning - B17 heads and cams (VenGeanceDrag)
nice ...thinking of building my b17, good info
Old Aug 17, 2006 | 04:06 PM
Downey's Avatar
very impressive.
my friends b17 made 155whp 109 tq (stock b17 head, block, manifold & tb)
iceman intake, dc 4-2-1 header, high flow cat, rsr exhaust and ctr cams.
yours also has TONS more midrange!
Freshdot
May 17, 2011 05:32 PM
hybridnorth
Jul 14, 2005 10:51 PM
ALMXDUPINTEGRA
May 11, 2005 02:46 AM
athoughts
Jan 21, 2005 02:32 PM
insnimprtguy
Jul 17, 2002 02:11 PM
