Serious question
Old Jun 12, 2006 | 05:30 AM
toddone's Avatar
Default Serious question
I just got done doing a swap on a 90 accord. Swapped the f22a for the f22b. The car run perfect up until 4800 rpm's at which point it act as though this is the rev limiter. I have done several swaps on many different hondas and at this point I am stuck. Need the help of the guru's. Anyone got any ideas why this is happening?
Old Jun 12, 2006 | 05:44 AM
Ross 2.0's Avatar
In a Junkyard near you.
so once you get to 4800 it just dies?
What ecu are you using?
Old Jun 12, 2006 | 10:43 AM
acc9ord3's Avatar
Default Re: (MooGoCow3)
i dont know if this would matter, but are you using a vtec ecu on a non vtec motor?
Old Jun 13, 2006 | 06:58 AM
toddone's Avatar
Default Re: (acc9ord3)
I have tried the stock ecu, a p13, and a p28. Same problem with all of them. The p28 gets close to 6k before it starts breaking up. I notices that the speedo wasnt working and the sensor is plugged in. I am going to replace that today. Also I already tried a couple different dizzy's. Any help would be great.
Old Jun 13, 2006 | 09:35 AM
YeuEmMaiMai's Avatar
ecu in limp home mode at 4800 redline
Old Jun 13, 2006 | 10:23 AM
toddone's Avatar
Default Re: (YeuEmMaiMai)
So the ecu is in limp mode? Why and how do I fix it. I have been researching on my own and I read that the accord will break up in the rpm band if the oil pressure is low? Any ideas? Anyone? I am going to check the oil pressure. Check back here in a little while.
Old Jun 13, 2006 | 11:24 AM
Default Re: (toddone)
check engine light on?
I wold recheck all of your wiring.....
Old Jun 13, 2006 | 02:06 PM
toddone's Avatar
That is the thing. I am not throwing any codes. As far as the wiring goes. The only wiring that needs to be done is the the vtec wiring. Everything else is the same. Just extending some of the wires. Also all wires are soldered and heat shrinked. All the wiring checked for continuity. I think it has to do with the oil pressure. Has anyone else had this problem. THe car runs perfect up until about 4500-4800 it starts breaking up. It wont rev higher than that no matter what ecu or dizzy I put in.
Old Jun 14, 2006 | 06:04 AM
JimBlake's Avatar
What needs to be done with the VTEC wiring? If your VTEC solenoid or VTEC oil pressure switch aren't hooked up, it SHOULD be throwing CELs for them. Does your CEL come on (lamp check) when you first turn it on?
Old Jun 14, 2006 | 06:28 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">ecu in limp home mode at 4800 redline</TD></TR></TABLE>
Bingo! check your spped sensor..unplug it fro mthe tranny clean it with some break cleaner..scrape it(connectors) with a wire brush..VOILA should work..a F22a to F22b should not be hard at all....only other wires are ground, oil pressure, voltage..correct me if I'm mistaken??
Old Jun 14, 2006 | 06:47 AM
khunt0012's Avatar
Meat Robot Invisible
Default Re: (I got the CD5 Jeebies!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">
Bingo! check your spped sensor..unplug it fro mthe tranny clean it with some break cleaner..scrape it(connectors) with a wire brush..VOILA should work..a F22a to F22b should not be hard at all....only other wires are ground, oil pressure, voltage..correct me if I'm mistaken?? </TD></TR></TABLE>
Correct.
I know I had this same problem with my H22 Accord. Woudln't rev past around 5000. Couldn't figure out for the life of me what it was. Tried multiple P13, some chipped ECUs, nothing worked. I decided to say expletive it and I replaced my coolant temp sensor, oil pressure sensor and TPS sensor. It worked and has been running great ever since.
Old Jun 14, 2006 | 11:37 AM
toddone's Avatar
I meant the only wiring that needed to be done w/the swap was the vtec. and no I an not throwing anycodes at all. I am in the process of replacing all the sensors and I got a new speed sensor on the way. Will let you know. Thanks
micban
Engine Management and Tuning
Mar 16, 2016 06:29 PM
slopaz
Jan 17, 2013 09:42 PM
lovindavtec
Jul 11, 2012 09:38 AM
scottypippen147
Oct 18, 2010 10:21 PM
ICEMAN707
Mar 20, 2006 05:42 PM
