Need Help Looking at 94 Accord
Old Jun 12, 2006 | 04:35 AM
dnkrm's Avatar
Default Need Help Looking at 94 Accord
Looking to buy a 94 Accord today and want to know what to look for. The owner said the brakes need work which I assumed was a pretty easy fix. After reading a few posts it looks like it might be more difficult than I thought. How can I tell if there is problems with the ABS or speed sensor for the abs? Anything else to look out for? thanks
Old Jun 12, 2006 | 05:50 AM
Ross 2.0's Avatar
In a Junkyard near you.
what are the brakes doing that they need help?
Fixed the tpyos
Modified by MooGoCow3 at 8:33 AM 6/12/2006
Old Jun 12, 2006 | 06:11 AM
dnkrm's Avatar
Default Re: Need Help Looking at 94 Accord (dnkrm)
they are causing the steering wheel to shake when slowing down at highway speeds according to the current owner. I would assume it is just rotors but what else would i look for? How hard is it to replace the rotors with the hub over rotor setup on the accords? thanks
Old Jun 12, 2006 | 06:12 AM
Ross 2.0's Avatar
Have the rotors measured with a micrometer.
they may be able to be machined to fix the warpage problem. Those are a pain to replace.
Old Jun 12, 2006 | 07:30 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnkrm &raquo;</TD></TR><TR><TD CLASS="quote">How hard is it to replace the rotors with the hub over rotor setup on the accords?</TD></TR></TABLE>
1997 Accord Brake Tutorial
Applies to all 90-97 Accord front brakes
Some options you have when replacing the front rotors.
V-6 Front Brakes on a '95 4cyl
95 Accord Legend 2 Piston Brake Upgrade
5th Gen 5 Lug Swap and Brake Upgrade
Rotor-Over-Hub Conversion
Old Jun 12, 2006 | 07:33 AM
Ross 2.0's Avatar
Default Re: Need Help Looking at 94 Accord (TouringAccord)
nice having someone do the work for me
Old Jun 12, 2006 | 07:57 AM
dnkrm's Avatar
what should be left on the rotor if I measure them? Can they machine the rotor while it is still on the car? thanks
Old Jun 12, 2006 | 08:19 AM
H-T Order of Merit
I believe the max refinishing limit on the front rotors is 23mm. I'll have to double check that in my manual when I get home but I think thats what it is.
Your local brake shop should have the tools to turn the rotor while it's on the car.
trickster kid
18
Aug 25, 2009 12:34 PM
ak768
Apr 2, 2009 08:24 AM
portaman03
May 27, 2007 08:15 PM
NWAS
Feb 20, 2003 07:02 AM
Padronis
Jun 27, 2002 07:56 AM
