gains on f22b1
was wondering what kind of whp gains i should expect with the following set up
1996 Honda CD7 Accord
F22B1 SOHC Vtec
F22 tranny with OEM Prelude clutch and flywheel
Kteller/Rm Spec F22b1 Camshaft 210/205 duration @ 0.050 11mm lift
AEM cam gear
Rocket Motorsports Retainers
Rocket Motorsports Speed Stable Valve Springs
SRT4 550cc fuel injectors
Hondata Heatshield Intake Manifold Gasket
Injen Cold Air Intake
MSD Ignition
Megan racing 42-1 2 piece header
Megan racing test pipe
2 1/4 Tanabe Hyper Medialion Exhaust
Chipped and tuned OBD1 P28
Modified by DAGAME at 7:24 AM 6/12/2006
F22B1 SOHC Vtec
AEM cam gear
MSD Ignition
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 »</TD></TR><TR><TD CLASS="quote">What is the motor in?</TD></TR></TABLE>
I assume...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAGAME »</TD></TR><TR><TD CLASS="quote">1996 Honda CD7 Accord</TD></TR></TABLE>
I assume...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAGAME »</TD></TR><TR><TD CLASS="quote">SRT4 550cc fuel injectors</TD></TR></TABLE>
Why do you need 550cc injectors? If your looking for larger injectors, wouldn't H22A1 345cc injectors be enough for that setup?
Modified by DAGAME at 7:24 AM 6/12/2006</TD></TR></TABLE>
convenient edit
i would guess about 30HP at the crank
convenient edit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 »</TD></TR><TR><TD CLASS="quote">i would guess about 30HP at the crank</TD></TR></TABLE>
Would you even need larger injectors for that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">Would you even need larger injectors for that?</TD></TR></TABLE>
certainly not 550cc. and then you would need to be able to control them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 »</TD></TR><TR><TD CLASS="quote">yea to waste more gas
and the black smoke is cool too
I was being generous. But not a bad start i guess. </TD></TR></TABLE>
im all about wasted gas and black smoke lol
and the black smoke is cool tooI was being generous. But not a bad start i guess. </TD></TR></TABLE>
was thinking of using the 550's cause my roomate still has his stock injectors off his SRT4, but i also have some obd1 345's, just looking some good power out of a F22b1 to be just as or faster then a stock h22, and wanting to keep the compression as low as possible so i can boost 10 lbs to the F22 in the future
EasyToNV
Sep 8, 2004 06:53 PM
Spxxc
May 31, 2004 09:32 PM
