will 96-00 civic suspension fit 92-95 civics?
Did a search with no answer, Just curious since I recently upgraded the suspension on my 97 EJ8 which had a pretty nice setup up previously and I have a 92 VX that is in need of a new setup. TIA for any help you may provide
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verycleanhatch »</TD></TR><TR><TD CLASS="quote">The front will fit. The rear you will have to grind down the bushings for it to fit which was a bitch for me.
Get 94-01 Integra suspension that will work no problem.
</TD></TR></TABLE>Get 94-01 Integra suspension that will work no problem.
The reason I asked is because I already have a decent setup from my 97 EJ8 and looking to re-use if possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoink »</TD></TR><TR><TD CLASS="quote">The reason I asked is because I already have a decent setup from my 97 EJ8 and looking to re-use if possible.
The front will, but the rear will require modification.
