BLEEDER VALVE
Old Jun 11, 2006 | 08:24 PM
r1de4life's Avatar
Default BLEEDER VALVE
alright so bleeding my clutch cause the pedal stays on the floor at all times.i disconnected all the hard lines to bleed them form each with a mity vac and it would suck the air out ontil of course i go to the bleeder valve.it wouldnt do anything.so i took out the bleeder completely and started sucking air out from just the hole and it was working good i can hear fluid and air going threw the lines and everything...so is my bleeder valve the problem?
Old Jun 12, 2006 | 10:17 AM
r1de4life's Avatar
Default Re: BLEEDER VALVE (r1de4life)
bump
Old Jun 12, 2006 | 11:23 AM
r1de4life's Avatar
i can hear something happening at the master cylinder but i cant figure out what it is...only a little bit of fluid and air is coming out of the slave cylinder with the bleeder valve off...and the clutch still will not get any sort of pressure.someone has got to have some ideas on whats going on?
Notahondatech
Transmission & Drivetrain
Oct 27, 2018 07:31 AM
r1de4life
Jan 16, 2006 10:06 AM
timsch75
Sep 27, 2005 07:46 AM
draygenx
Mar 21, 2005 09:21 PM
xerox445
Oct 20, 2003 10:15 AM
